coachgeo
- 3,534
- 113
- North of Cincy OH
... contact member mototech for the A1 TM'sI am going to ask again........ anyone have the wiring diagram for a Gen 2?
How do I contact him?... contact member mototech for the A1 TM's
Never mind...... website worked. Thanks!How do I contact him?
I did a search and found nothing. Maybe Tapatalk does not search people well? Will keep looking.
Sent from my iPad using Tapatalk
We have installed a couple of A / C units in LMTV. This will require the condenser unit, the A / C compressor, some custom-made lines, supports for mounting the compressor and the front crankshaft pulley to operate the compressor belt. We had to customize the brackets and the front pulley. If someone is interested, I can probably do another set, although I'm not sure of the cost.
I am making a custom condenser based on the belief / advice that the condensed should be 60,000 btu. Using 2 CNFP2222 AC Universal Condenser Parallel Flow 22 x 22 w/ #6 & #8 Ports and 2 fans.Just curious who has tried a non-OEM condenser with a gen 2 unit. Were the results good?
You ever get an answer on this?I am going to ask again........ anyone have the wiring diagram for a Gen 2?
Do you put them in para or series?I am making a custom condenser based on the belief / advice that the condensed should be 60,000 btu. Using 2 CNFP2222 AC Universal Condenser Parallel Flow 22 x 22 w/ #6 & #8 Ports and 2 fans.
Did the condenser you bought fit the existing mounts, or did mount need to be fabricated to make it fit?I had them in parallel but ended up with just one and it is fine. 22" x 22" aftermarket condenser for less than $70
I have one of the same. Hopefully the Italian Fans will provide enough CFM.I had them in parallel but ended up with just one and it is fine. 22" x 22" aftermarket condenser for less than $70
There are no existing mounts, I mounted it to the radiator frame. Easiest to remove the radiator from the truck to do this since you will have the shroud and fan off already.Did the condenser you bought fit the existing mounts, or did mount need to be fabricated to make it fit?
Sent from my SM-N975U1 using Tapatalk
Still have the second condenser you didn't use?There are no existing mounts, I mounted it to the radiator frame. Easiest to remove the radiator from the truck to do this since you will have the shroud and fan off already.
Yes, $65 shipped plus you will need 2 spall fans. Don't cheap out on the fans, these are made in Italy and are the same as OEM.Still have the second condenser you didn't use?
Price without shipping? I'll just pick it up from you.Yes, $65 shipped plus you will need 2 spall fans. Don't cheap out on the fans, these are made in Italy and are the same as OEM.
Sent you a text.Yes, $65 shipped plus you will need 2 spall fans. Don't cheap out on the fans, these are made in Italy and are the same as OEM.
