- 1,812
- 1,513
- Orlando, FL
I think a few things might be getting confused. The LMTV rims use a standard-style valve stem, but the valve core has been removed so that the CTIS can inflate/deflate it at-will. Usually what people are talking about is that they are looking for what kind of valve core to stick in the valve stem, in the event they need to remove the CTIS valves (e.g. because of damage). Otherwise, with the CTIS valves removed and no core in the valve stem, the air all just leaks out.My M1078 Tires/Rims use a regular Tire Valve inside the stem but the stem is not the ones they use on regular tires. I thought you could just fill each tire using the valve? When I pulled the Hose off the Hubs Stud that feeds it no air leaked? I have heard of a fitting you can use instead of the Air System that can screw into the opening on the rim.
