thesnieder
- 0
- 1
- Utah
I sent them to get rebuild because i wasn’t finding the parts to do soThe cards are easy to test and rebuild.
Edit. I wish you luck in your efforts to fix this gen set.
So i have it in and then i start the unit and then after the unit is running it trips so the panel goes dead but still running also when I switch it to stop it don’t turn off i have to throw the switch by the injector pump to get it to turn offYou need to explain to us exactly what happens. From the time you push in the CB1, to when the CB1 pops back out.
I think you hooked something back up wrong. You need to check every wire you unhooked before.
