Mep006a
thesnieder
Utah
Do you by chance know how hot these 60 K military generators run. I want to make sure I am painting The exterior frame with the right paint
thesnieder
Utah
You need to explain to us exactly what happens. From the time you push in the CB1, to when the CB1 pops back out.
So i have it in and then i start the unit and then after the unit is running it trips so the panel goes dead 💀 but still running also when I switch it to stop 🛑 it don’t turn off i have to throw the switch by the injector pump to get it to turn off
thesnieder
Utah
So I labeled everything before I disconnected it was the question I have is there a right way or a wrong way of installing the relays on the two circuit boards
Guyfang
27,279
Burgkunstadt, Germany
Doesn't matter how you stick them in.
I never mark wires. If someone else mad a mistake, you just repeated it. The wires are marked. The schematic is clear. Cant go wrong. If it worked before without popping the CB. and now doesn't. then the only other answer is something hooked up wrong.
