- 1,215
- 2,163
- Wenatchee, WA
In an effort to compensate for the power loss of running 16.00-20s (still a future mod), I started accumulating parts for adding a turbo to my NHC-250. The direction I'm going is nothing new as @Lonnie has already laid the ground work for the turbo layout I'm using, but I was also inspired by sbkarmen and Sevin7 who also mounted theirs backward. Lonnie's routing solved some issues and checked some boxes for my install that lets me retain the factory intake and its cold starting features, does not interfere with where my heater ducting will enter the firewall by the PCB and doesn't require that I spend a month on an english wheel to make a cross over tube to fit between the hood and jake brakes.
Before attempting a turbo add-on I wanted to have several things in place so now that I have a pyro and boost gauge to keep an eye on the vitals, the jake brakes installed which would affect pressure pipe routing, and my heater location figured out, I'm finally ready to put the turbo on!
![20200529_171759.jpg 20200529_171759.jpg](https://www.steelsoldiers.com/data/attachments/593/593674-8ecc9eafd3ed60afc6ec98d5f6388889.jpg)
![20200417_184345.jpg 20200417_184345.jpg](https://www.steelsoldiers.com/data/attachments/593/593675-98c0f4b33b86f90b05f8e46b734c8dbe.jpg)
![20180920_173309.jpg 20180920_173309.jpg](https://www.steelsoldiers.com/data/attachments/593/593676-972ff692ce1a0a245b11ba44c49abc16.jpg)
Typically my projects are completed before I do a write-up on them but this one is still underway so follow along and I'll update as I make progress. I'm a detail guy so I'll have plenty of photos of the parts, the steps involved, and the cool parts I got to produce to make this all work out!
All of my favorite car shows were cancelled back in May and June so I started the teardown in early May.
![20210506_124627.jpg 20210506_124627.jpg](https://www.steelsoldiers.com/data/attachments/593/593677-d614a5ff71c12d8c41238af9cb9693ff.jpg)
The muffler bolts wouldn't budge even after 3 days of soaking in Kroil and other things so after snapping off a reducer with the impact wrench I just yarded out everything in one piece. The manifold bolts came right out with just a few tight squeaks![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![20210506_131204.jpg 20210506_131204.jpg](https://www.steelsoldiers.com/data/attachments/593/593678-2e5ea57f7515db5611750c0aa9b3e3e5.jpg)
![20210506_131216.jpg 20210506_131216.jpg](https://www.steelsoldiers.com/data/attachments/593/593679-20d4a7eae23bc5cec79c6826f31116e8.jpg)
Shipments of part$ started rolling in such as the new-style pulse manifold, the Borg Warner BHT3B turbo, the silicone elbows and aluminum pipes, 5" exhaust parts, and some hose fittings.
![20210329_160638.jpg 20210329_160638.jpg](https://www.steelsoldiers.com/data/attachments/593/593680-b8785674da2e4d35a8e65f8f2952174a.jpg)
![20210329_162906.jpg 20210329_162906.jpg](https://www.steelsoldiers.com/data/attachments/593/593681-94c76a047036845aa560c52f1b67713f.jpg)
![20210407_103233.jpg 20210407_103233.jpg](https://www.steelsoldiers.com/data/attachments/593/593682-d7f922e29c26ce42939f32f04dfe151a.jpg)
![20210407_100619.jpg 20210407_100619.jpg](https://www.steelsoldiers.com/data/attachments/593/593683-5531434438aa277082d340fb829b79e1.jpg)
