- 4,515
- 2,597
- East of Edmond, Oklahoma
So was looking under hood after checking engine oil and noticed a few grains of white stuff under the battery hold down plate.
I instantly knew what that was and took it off to clean it.
Corrosion has worked it way under the rubber coating quite a bit.
Cleaned as best I could and banging it lightly on the brush Guard did wonders. A lot more white crumbs came out. Much more than expected.
Flooded the area with ACF50 anti-corrosion spray and allowed it to soak and creep in.
Reinstalled hold-down and will keep closer eye on it in the future.
This is the third issue in two days.
Front Wheel bearings, then oil cooler lines start leaking and now this.
Been at least a year since any real issues.
It was due…….
It was due…….
