- 488
- 366
- 63
- California
Hi, I am back in the trenches, hope everyone had a good Thanksgiving!
I believe that I found the check valves, in front of the fuel tank, under rear passenger, like you said:
![CheckValves.JPG CheckValves.JPG](https://www.steelsoldiers.com/data/attachments/607/607499-4399aaddedc18d8bac9efb6a47fcb03e.jpg)
I also replaced the fuel filter and water separator and replaced the short 3/8" hose connected to the fuel pump, it had a crack and it was leaking. There is another 1/4" fuel hose that is leaking at the connector, but some it may come from higher up in the engine. Is this a return line? It's hard to tell where it goes and how to get to it in order to replace it, please see attached picture:
![Fuel hoses leaks.jpg Fuel hoses leaks.jpg](https://www.steelsoldiers.com/data/attachments/607/607497-94a8d73b3b980b855983addc3a0ce237.jpg)
(picture before cleaning and replacing - shows the leaking)
![Leak 2.JPG Leak 2.JPG](https://www.steelsoldiers.com/data/attachments/607/607500-8b7147d0f53692ba123380ff28db7321.jpg)
In the process I broke the 1/8" plastic line, which presume it is not critical like the diesel hose (found Gates Barricade rated R14 at 225PSI at O'Reilly - 27339 = 1/4" I.D. and 27341 = 3/8" I.D. - the fuel hose I took out was R7.
