- 488
- 366
- 63
- California
Here are the pictures, it looks like there were no screws or other parts installed in those nutserts. (the rubber elbow lost the paint on its edges when I replaced the air canister):there are 3 nutsert holes in the body around your fording intake stack. Can you see marks in the paint from where this was on your truck? They hold a flange that connects to elbow on bottom and the rubber sleeve on top. But this uses a shorter intake stack...
![Air Cleaner3.JPG Air Cleaner3.JPG](https://www.steelsoldiers.com/data/attachments/610/610373-f5b7c7cc05336bd8754ce9c97eb7f328.jpg)
![Air Cleaner4.JPG Air Cleaner4.JPG](https://www.steelsoldiers.com/data/attachments/610/610374-038738ef5e8eb2fc76eeaa208459d0ad.jpg)
BTW, I was able to finally drive it with the GPS on the freeway and it went up to about 81mph.
I would like to have it run around 85-88mph at 2500rpms, where the engine sounds very buttery
Found this article about increasing the fuel supply to the injection pump:
Turn Up the Fuel on a 6.2 - 6.5 GM Diesel Mechanical Injection Pump
flashoffroad.com
I am all about measurements and can see how to add a thermal probe to get the EGT, but how about the transmission temperature? Is there a temp sensor already inside? Any other sensors on board that are maybe used for diagnostics, and which could be used for external measurements like the boost PSI?
I would think the engine has a lot more margin than that, but truthfully, you guys are the experts.
