Blower/heater M1165
Karl kostman
922
Fargo ND
Confirm in your TM that its a ground and you should be able to attach it to anything solid and close to the firewall, just make sure that whatever your attaching to is not rubber mounted.
Action
1,563
East Tennessee
Not getting any heat when I flip the switch to heat. Does this wire have anything to do with it and where does it ground to?
Look on the other side of the unit for the ground screw.
To get heat, you also need to turn the fan on....and the engine needs to be warm and running.
And if going from a/c to heat or the other way, it takes a minute or so for the water valve to move.
  • Like
Reactions: OBX
jim1131
36
Illinois
To get heat, you also need to turn the fan on....and the engine needs to be warm.
On the back side of the unit? Also engine was running, 200 degrees and had it on heat for over 10 minutes. Do you know how to test the valve?
Retiredwarhorses
4,528
Brentwood, Calif
That is the ground that should terminate on the fan motor, left side, it’s a fine thread 10/32 nut.
The hot water valve fails in an open state, it only closes when AC is selected.
