Not getting any heat when I flip the switch to heat. Does this wire have anything to do with it and where does it ground to?
Look on the other side of the unit for the ground screw.Not getting any heat when I flip the switch to heat. Does this wire have anything to do with it and where does it ground to?
On the back side of the unit? Also engine was running, 200 degrees and had it on heat for over 10 minutes. Do you know how to test the valve?Look on the other side of the unit for the ground screw.
To get heat, you also need to turn the fan on....and the engine needs to be warm.
And if going from a/c to heat or the other way, it takes a minute or so for the water valve to move.
Did the blower fan come on at all?On the back side of the unit? Also engine was running, 200 degrees and had it on heat for over 10 minutes. Do you know how to test the valve?
There is no diverter cable.Maybe the diverter cable came loose, or your diverter valve is plugged. You can service yoursekf
There isnt a diverter box to hook a cable to.how about the one that hooks to the back of the heater core with one small screw
