It appears to be a HF HM with an electric winch on it…Please tell me about your crane.
Yep. I had on on my M1078 and I have one in my M1082 trailer.It appears to be a HF with an electric winch on it…
I bet this thing really comes in handy for you to relocate the XXXL ones.Yep. I had on on my M1078 and I have one in my M1082 trailer.
Some rattle can camo and it's ready for an NSN....
For the truck I made a 4"x4" drop-in so it could be moved to any one of the four corner posts (that's what they are for).
Total cost is about $250 after paint.
Or you can get the real one for the LMTV if you want to piss away about $5000.
Both work equally well.
1/2 Ton Capacity Pickup Truck Bed Crane with Hand Winch
Amazing deals on this 1/2Ton Capacity Pickup Truck Crane at Harbor Freight. Quality tools & low prices.www.harborfreight.com
2000 lb. Utility Trailer Winch with Steel Rope
Amazing deals on this 2000Lb 12V Utility Trailer Winch at Harbor Freight. Quality tools & low prices.www.harborfreight.com
Now thats just wrong on so many different levels ! What the fattest girl you ever jigged up in that thing ? Does the truck lean over much ? I assume you have to keep the boom slid all the way in on the big lifts .
.Cruised to the coast to test CTIS sand mode.
View attachment 868327View attachment 868328View attachment 868329View attachment 868330
Did it work? Your tires look fully inflated.Cruised to the coast to test CTIS sand mode.
Actually it worked amazing! Yeah its hard to tell in the sand but those were down at 20psi. Its really noticeable the squish on pavement, but not so much in the sand. The CTIS complains if you go over like 12 miles an hour in the sand mode, so I tried cross country which is 35 psi I believe and it was markedly bumpier, so went back to sand and did the slow cruise.. I didn't want to get buck wild on my first trip to the dunes so I took it slow. You definitely need some momentum to climb steep dunes. I tried to slowly torque up one as a test and it dug in. All in all I was super impressed with the sand ability of this truck.Did it work? Your tires look fully inflated.
I also took a trip DQ for ice cream and to Oreilly auto parts. lots of looks as i backed that giant into a spot and went inside for my tasty treat. Guy at auto parts store asked if i could bring my big truck next time.Took a short cruise for an ice cream cone. Got lots of quizzical looks and many more thumbs up. Might need to think about installing a low-keyed but funny auxiliary horn. Took the long way home checking out the scenery.
My window crank stopped moving the glass up & down so I dug in to that. Found that the glass simply came out of the anchor bracket. Removed the deteriorated rubber gaskets & used pieces of an inner tube and adhesive to make new gasket / cushions.
While the door panel was off I thought I would reconnect the interior door lock. Decided to leave it disconnected since the key lock has no key & I would hate to have that door inadvertently lock and not have a key.
How much do those blocks weigh each?The 1084 got used this past weekend to set some retaining block at the parents house on the farm. Happenstance I was focused on what I was doin and didn’t get a picture of setting the block with the crane but here’s a roughly before and after pic
I did a bunch of 2x4x2 at about 2400 lbs each.How much do those blocks weigh each?
