RRaulston
- 546
- 93
- Sahuarita, Arizona
Here is the truck. 1997 MTV. Day one of the sort out was fruitfull. I was able to get the hydro pump to work after the rebuild. It took me 2 times to figure out I had the checkball in the wrong location. After I raised the cab for the first time, I discovered the rats chewed through some of the Intercooler pipe insulation. They also chewed through the Ether tubing. Everything else looked good. Engine appears to need a pan gasket and alternator belts. So, a few questions:
1) Is my fan hub the new style or the problematic one?
2) if I pump the fuel primer and it never gets hard/stiff, is it bad?
3) how the heck do you get the knobs off the hydro box so you can clean the orifice??
4) when I lower the cab, the red lock pin doesn't retract. No clue on this one..
Thanks all!!
Thanks all!!
