Here is an update to my progress.... I'm slow but I'll get it done eventually.
Yesterday I made a new pin for the parking brake lever. Used a 3/8" Grade 5 bolt, not the threaded part but the smooth shaft portion. I cut the head off, then clamped my dremel tool off the side of my workbench. Using a thin cutting disc, I held the bolt and cut a shallow groove all the way around. I got my kit of snap rings (lock rings?) and continued to deepen the groove slowly until I was able to use a small set of channel locks and snap the ring into place. Took it to the wire brush on my bench grinder to smooth it and remove any burs.
After getting the groove cut, I cut off the threaded portion of the bolt and dressed it. Then took a marker to "paint it" and used my dial calipers to scribe a line all the way around the bolt to mark the correct length and cut it with my angle grinder. Used the dremel tool to clean it up and finish it.
Looked good, so I set it up in my vice so that just enough of the top was sticking out of the parking brake lever
(for it to end up at correct length) and tac welded it. Tapped it with a hammer a bit to straighten it and finished welding it.
I'll just leave out that I welded it in backwards the first time, had to grind the weld off turn the brake lever over and reweld it....
In the end it worked. Maybe this will help someone else who has the same issue. This part is not available Anywhere. Unless you need the passengers side... found a brand new GM one on ebay... but none for the drivers side...
Today the self adjuster kits arrived. And between the TM's, some youtube videos, and looking at the passengers side brakes. I was slowly able to figure out how everything was supposed to go together. Took three hands to get the spring pulled back on the parking brake cable
and get the parking brake lever on the cable before letting the spring go. That spring is certainly tough, and no my parking brake wasn't on.
One thing I ran into was that on the new brake shoes, one shoe was longer and thicker than the other. Actually my Dad had come over to see what I was doing and he is the one that noticed it. The shoes that were on the truck were exactly the same in length and thickness. So wasn't sure if I had the wrong shoes or what.
Did some research online and found the consensus of several websites and some videos, that
*if* a set of brake shoes had one shoe that was longer and/or thicker than the other, then the the long/thick shoe went on the "rear side" of the wheel. As it takes more of the braking force and is also the parking brake, and other opinions. In any case, this made sense to me so thats how I installed them.
So the drivers side is done, all new parts from the wheel cylinder all the way up, with the exception of the repaired parking brake lever and cable. Brake line fitting turned out of the wheel cylinder just fine, and the lines are good and solid so I'm leaving them. But I am going to replace the rear brake hose.
(will also replace front hoses when I get to the front end).
I will say, it has been several years since I installed brake shoes
( the last one's I did was on an 90's model GM Suburban)... but the way the springs and etc are setup on this truck, its the hardest one's I've ever had to do. Had to use two bar clamps to hold the first shoe in place while getting the initial pins and springs on there, and still could have used three hands...
Also the diagram in the TMs aren't great in showing how it's assembled, and are missing a couple parts completely. Even though I had photos of this hub, because of all the thick oil and the parts that were missing/fell out of the bottom when I removed the drum, the photos didn't help much. I'm glad I waited on taking the passengers side apart.
Spent
way to much time just to get one side done today. Good thing I don't own a mechanic shop, I'd go out of business.
Anyway, the passengers side should go much faster now that I know where all the parts and spring go. Should be able to get that done tomorrow unless something comes up. Then just be waiting on the axle nut socket.
hum... have to fix that wheel cylinder pin...
![Rolling Eyes :roll: :roll:](https://www.steelsoldiers.com/images/smilies/icon_rolleyes.gif)
