Valley Rock
Big wheeler cat peeler
525
Rogue Valley OR
Saw no reason for the stock configuration to leak, yet they did, not anymore
Edit: in hindsight I do not at all care for the shiny aluminum parts on my engine, wish I had painted it first and I shall still, with a little brush, maybe filters too with a spray can 😎
Micmada
211
Florida
Oil filters are not too much a problem for me so far, however the fuel filters are another story. Definitely will look into a spin on set up for at least the two twin secondary filters.
Computerdoc08
213
Florida
Finally finished a large serving on Deuce 2 to include:
6 new inner hub seals
4 new outer axle seals
2 new front axle tube seals
6 new axle lock washers
6 new brake cylinders and associated banjo bolts, washers, etc.
All new rubber brake lines
4 new hard lines on front and center axle
Power bled brakes twice with DOT 5 silicone fluid
New heavy duty tie rod from Boyce Equipment CO.
2 NOS tie rod ends
4 New king pin bushings and shims
2 new black silicone axle boots
4 new boot clamps
2 new inner wheel bearings on front axle
2 new outer wheel bearings on front axle
24 new spindle studs with new washers and nuts
Used a thread chase on all 36 wheel studs
CONSUMABLES
Over 100 cans of brake cleaner
9 rolls of blue shop towels
1 can of Cyclo Break Away
All said and done, it was tons of fun!
biscuitwhistler37
733
Michigan
2 NOS tie rod ends
4 new boot clamps
CONSUMABLES
So buy brake cleaner by the barrel. Noted 😃
Micmada
211
Florida
On second note, I hear the stock ones do not have the backflow valve like spin ons.
Where do you get a kit.like this?
Computerdoc08
213
Florida
More work on Deuce 2…
Replaced 6 fuel injectors, new copper washers and new rubber injector seals
Replaced fuel Injector return line to include all new fittings
Replaced primary fuel filter
Replaced fuel tank to primary filter head hose
Replaced hose from primary fuel filter head to injection pump
Replaced fuel hose to flame heater and replaced flame heater filter
SCSG-G4
PSVB 3003
3,205
Lexington, South Carolina
I doubt you will ever need the flame heater while in Florida. It's primary use was to heat up the incoming air enough to get the LD series engines to start when the temp was at 0 degrees F or lower. All new lines will help, but it remains a point of failure that most of us in the south can avoid.
Computerdoc08
213
Florida
We have property in the Pacific Northwest and I will be taking Deuce 2 out there so want to be able to start in the negative temp range. Deuce 1 has its flame heater deleted as it will live in Florida,
speaking of flame heater, I was sold this replacement spark plug with a different part number than the Autolite currently in the truck. The old PN is 1093558 the new PN is a Champion 733556; are they compatible? The new one has an offset tip from the center electrode. The NSN of the new plug is 2920-00-411-5747.
Dipstick
1,267
Effort PA
Hello my friends! It's Dipstick. I hope some of you remember me. I sold Brutus several months ago. As I am rapidly approaching 71 years of age, I felt I was no longer able to maintain Brutus the right way. That along with rust and my constantly dwindling financial status also took they're toll. I now drive a 2012 Jeep JK, which is remarkably similar to driving a Deuce! It feels like I'm driving a mini-Deuce. I love it. I hope everyone is doing well!!!
