Scoobyshep
- 2,188
- Florida
That's the strainer if you order a set of wix filters you can rob one of the gaskets out of the filter kit and use that
I know for a fact the one from the filter kit will fit I have done it on that exact modelCan you make out the shape of this gasket ring?
Are the filters the same in all three canisters? If I'm replacing one, I guess I should replace all, that is if they exist. When I order the filters, do you have a preferenceThat's the strainer if you order a set of wix filters you can rob one of the gaskets out of the filter kit and use that
Where did you purchase the filter kit? This is crazy, this is the only thing that's holding me up.I know for a fact the one from the filter kit will fit I have done it on that exact model
All I can find so far are the spin on filters and they require a new mountaing. Did you have that problem? if not I need to know the site for the drop in filters.Are the filters the same in all three canisters? If I'm replacing one, I guess I should replace all, that is if they exist. When I order the filters, do you have a preference
sorry had to get back to the office, Amazon, Wix 33511. buy 3 of them. use 1 gasket in the strainer, use the other 2 to replace the filters and gaskets. the unused filter can be used later with the replaced but slightly used gasketAll I can find so far are the spin on filters and they require a new mountaing. Did you have that problem? if not I need to know the site for the drop in filters.
Waiting for the filters now, but just another small issiue. What tool do you use to remove the filter canisters ? I used and oil filter wrench and was successful getting one off but the other two refuse to loosen. I'm sure i'll figure it out, but if you have a special tool.sorry had to get back to the office, Amazon, Wix 33511. buy 3 of them. use 1 gasket in the strainer, use the other 2 to replace the filters and gaskets. the unused filter can be used later with the replaced but slightly used gasket
Strainer undo the nut at the bottom of the bowlWaiting for the filters now, but just another small issiue. What tool do you use to remove the filter canisters ? I used and oil filter wrench and was successful getting one off but the other two refuse to loosen. I'm sure i'll figure it out, but if you have a special tool.
Really thanks for that, I could see the drain plug, but that little nut missed my eye. Sure helps to what the H your doing.Strainer undo the nut at the bottom of the bowl
Filters take the large bolt off on the top center of the housing (think its 5\it has a smallwr bolt sticking out of it (1\4) that's also your bleed screw).
OH, He who knows all,Other helpful things to look at: pay close attention to the IN and OUT on the filter castings, Ive had these backwards before. change the filters and open the bleed screw on the first filter (center unit) and set the main switch to prime and run. when fuel leaks from the bleeder do the same on the 2nd filter.
modern diesel (ultra low sulfur) isnt as oily as older fuels, I would recommend a lubricant additive. I personally use a product on amazon called Hot Shot's Secret Everyday Diesel Treatment.
Assuming 120\240 mode which is 52 amps 6 awgOH, He who knows all,Would you know what size cable wire to run from gen. 15FT to meter transfer box?
