Autonomy_Lost
- 1,537
- 93
- Pennsylvania
I did the same, but mounted the camera higher, up under the shelf that the Rhino locks into. Putting it there allowed the camera to be more protected and still allowed for an unimpeded view.Started installing a backup camera:
PIC?I did the same, but mounted the camera higher, up under the shelf that the Rhino locks into. Putting it there allowed the camera to be more protected and still allowed for an unimpeded view.
PIC?
Hmm, thats not a bad idea. So basically the top bolt of the same bracket? I guess I was worried that the tire would block it. I'll have to try that.I did the same, but mounted the camera higher, up under the shelf that the Rhino locks into. Putting it there allowed the camera to be more protected and still allowed for an unimpeded view.
I'm out of town for business travel at the moment, but I'll see if I can't get my son to snag a pic for me.
Check with [B]aghumvee[/B] I purchased some NOS doors from him and I am very happy with the quality and price, there were some small imperfections (small brown spots) in the windows but it is hardly noticeable and of course this was discussed beforehand, He is a good guy!!!Got the 2-man soft top installed on my M1114 today. Next step, soft doors.
Thanks. I've already got a set. The only problem is that they're camo color.Check with [B]aghumvee[/B] I purchased some NOS doors from him and are very happy, there were some small imperfections (small brown spots) in the windows but it is hardly noticeable and of course this was discussed beforehand, He is a good guy!!!
Is that Motorola mic connected to a Spectra or maybe an XTL?I took the advice here and moved the backup camera:
Also finished the install with the monitor and everything. Its hooked up to the TCM power feed wire, so turns on and off with the start switch. It stays on full time when running (I dont want to need to be in reverse to use it).
Its a Motorola XPR4550, UHF low split so it can do HAM, GMRS, and commercial. Its also hooked up to my intercom system on the receive side. Still need to hook up the intercom for transmit though (hence the mic).Is that Motorola mic connected to a Spectra or maybe an XTL?
Ahhh, you fooled me by slumming with the XTL mic..Its a Motorola XPR4550, UHF low split so it can do HAM, GMRS, and commercial. Its also hooked up to my intercom system on the receive side. Still need to hook up the intercom for transmit though (hence the mic).
Haha, I like the old school micsAhhh, you fooled me by slumming with the XTL mic..
You doing the Auburn parade?Time to change the oil. It wasn't quite at the mileage point but it isn't raining and the parade is tomorrow, so why not.
