- 254
- 831
- 93
- USA Indiana
I’m curious why you chose the sealer you used? Not exactly what is called for in the instructions. Let me know how it works.
Mike
Mike
A good friends recommendation. He used it on his axles for other vehicles and had good success.I’m curious why you chose the sealer you used? Not exactly what is called for in the instructions. Let me know how it works.
Mike
Yep, halve the pulses per mile for the speedometer if you have the stock 3.90 gears and 395/85R20 tires. The tachometer doesn't need to change.Does anyone have the P/mile setting needed for EcoHubs on the C7?
Is it just 62618/2 =31,309?
Anything need to change on the tach calibrationView attachment 936227?
No lakes or tar pits nearby? I guess if all else fails you can go on a walkabout and try to throw them off the end of the Earth so they can no longer hurt anyone else.That’s a wrap
Now I need to find a place for this crate.
I have been thinking using them to build a zen dripping water feature—You could probably weld them together to make a cool boat anchor![]()
Want 4x more zen?I have been thinking using them to build a zen dripping water feature—
If everybody can post their * loaded *mpg on here, with the conversion that would be a great way to show the Benefit to potential buyers.Agree, I’ve travelled 25,000 miles on the 3.07 gears. But my last short trip with the newly installed eco hubs of 800 miles…..so so different sound level, much easier to have a conversation. The fuel mileage. Totally different experience.
Good info- TYGunny,
I am just shy of 9.0 MPG at 28k #'s if I keep it under 65 MPH on the level when rolling down a freeway. Hills will slow me down a bit but never slower than big rigs. Mix in off road stuff and I am actually right about in your range. Over the course of a long weekend trip- like 4 days, 200 miles, mix of paved and dirt- I'll get around 8 MPG.
2000 M1088A1, ~28k, 3126, 330hp, ECO hubs, 3.07 gears, 12' 6'" tall, 8' wide, 23' box
FWIW, I am seriously considering swapping back to 3.90's in the near future. The 3.07's make the shift to 6th happen at 65, but 3.90's would put that around 52 (if I math correctly). Keeping it in the power band in the high-50's seems like it'd be perfect for me. The 3.07's make me want to run 70 MPH...
I know the MPG doesn't sound like a HUGE delta, but the reduction in drivetrain speed was what made the decision a no-brainer on my end.
Chris
I’m 4 wheels 28,000 lbs 3126 with 330hp tune. With my 3.90 gears and eco hubs 6th gear shifts in around 60MPH. I tried grabbing 7th but after hitting 80mph I gave up. I topped off the 200 gallon tank and drove the 800 miles but haven’t filled it back up to determine the actual fuel mileage. But with the new BlueFire and watching the instant fuel rating I was getting around 9 mpg up from 6.5 mpg gaging it the old school way…fill up to fill up.
