hethead
- 225
- 43
- Seattle, WA.
Thanks for posting the follow up. "Cummins turbo'd the NHC 250 (making the NHCT 270) and so should you!" That's a nice, well thought out set up you have. I wouldn't be surprised if your boost goes back up a few lbs after you put the higher flow injectors in. You have lots of room to safely add more fuel with those EGT numbers.
