Polaris MRZR-D4
Lawdog734
134
Colbert, GA
Based on drive belt number 3211193, the following belts should be compatible with the MRZR-D4: Gates 36G4246, 36C4246, 36R4246, Dayco XTX228, Sixity belts compatible with the aforementioned belts, and maybe others that I'm not aware of. It's that correct? I've been trying to order Polaris belt # 3211225 through Amazon, but the seller keeps sending belt number 3211148.
Where are you finding that 3211193 is compatible with the MRZR-D4? I was also under the impression that 3211225 was the appropriate belt.
As far as aftermarket belts go, there are some good ones and others that aren't so good. The general rule of thumb seems to be to stick with OEM belts.
publicenema
32
Ottawa, On, Canada
The D4 uses belt 3211225, and it's used exclusively on 2017 through current MRZR D4's. As such, it's likely a controlled part and will not be available to you. I'm unable to cross it to an aftermarket belt, but you may be able to remove it and find something by searching for something with similar dimensions..
The diesel ranger belt (3211193) may work, but the only way to know is to try.
Eltonich
Puerto Rico
On the attached picture it said that belt 3211193 was replaced by belt 3211225. I got the picture from the Polaris site. I ordered the Gates belt, and as soon as I get it I’ll do a side by side comparison.
Lawdog734
134
Colbert, GA
Finally got my hands on an MRZR-D4 and man is it fun. I had originally intended to strip it all down and restore it, but I think I'm going to leave it as-is. It looks like honest wear without signs of any real abuse.
After checking fluid levels and the belt/clutch conditions, I took it and had a little bit of fun with it. Everything runs great, but the shocks definitely need to be rebuilt. I've thought about respringing them myself, but I know that the right answer is to have them rebuilt.
The 28" tires aren't bad, but I've given some thought to stepping up to the 30" or even 32" version of the stock BFG tire. Has anybody played around with a slightly bigger tire?
Eltonich
Puerto Rico
I can get if it's not a discontinued part. I believe the 2017's used a metal guard, part 1023088-329. Might have to be updated to the plastic guard on the 2018-up.
Yes, is a 2017 model. The plastic guard should be part number 1023899? Please let me know if you can get it, and how to send you the payment. Thank you!
