Got the truck all stripped-down, and I'm putting together a list of parts to order. Finally going to get started on this engine-swap. Who's got oil pan gaskets in stock, and can I get a pre-made gasket for the mating surface between the block and the bellhousing, or should I just make one? How thick should it be?
Planning on switching over the 2.5-ton oil pickup and crossover tubes, re-torquing the mains and rods, flipping the oilpan around, re-torquing the head bolts and valve adjustment screws. Will also be reusing the 2.5-ton MF bellhousing/adapter, flywheels and starter spacer. Have a new 2.5-ton clutch to install.
What about the
updated rear main seal? Would hate to have that start leaking right after I get the engine in there.
Need to figure out how to check to make sure the booster pumps spins freely.
Will pre-lube before start-up, but I'll probably post-back to ask how...
I've got a couple of different universal clutch alignment tools, but they're for smaller cars/trucks. Will that work, or do I need to buy a clutch alignment tool specifically for the Deuce?
Anything else?
