IdahoPlowboy
- 13
- 18
- Ririe Idaho
This week I had the leaf springs re arched with 2 inches more lift and installed new ORD greasable bushings and their heavy duty shackles front and rear.
How do you get the blackout effects on your lights?couple new pics for update, got the new tires on and wheels, now running 39x13.50x17r BF-Goodrich Baja KR tires on 17 Inch caddy esclaide wheels. still need a new rear window, crank and gaskets though.
Where'd you get the switch from? Depending on where you live, you might not want a keyless ignition. I know here, my truck would be gone in a heart beat.You know i thought the same thing, i sprayed some in last night thinking maybe some assembly grease was causing the tumblers to stick open...maybe i just need to break it in.
