IdahoPlowboy
- 13
- 18
- Ririe Idaho
I have been thinking about putting a turbo on my 6.2 and have wondered the same thing about putting a turbo on a probably well used engine, I really dont know the answer for sure.
[FONT="]I have been thinking about putting a turbo on my 6.2 and have wondered the same thing about putting a turbo on a probably well used engine, I really dont know the answer for sure.
what is wrong with the one IN your truck? it is the same as all the others and yes the 700r4 is all self contained (no wires or vacuum lines). and yes use a trans cooler. if you want to do 65 then the 700r4 with an od is the best way to do it with a transmission. or you can just stick with the th400 and get larger tires.OK, new idea. What is the best 6.2 engine I can get? I am talking about upgraded parts, etc. I read to get a 1988 or newer and what transmission should I use? Does that mean a Humvee engine? I am looking for 4 gear non-computer auto if possible, OD does not matter.
I am seeing 6.2 diesel engines all over the internet, cheap. This we can do in my friend's garage.
What do larger tires do and what size?get larger tires
larger tires will give you a little more top speed
the motor in your truck is a 6.2 diesel so if you want to get more power out if it ad a turbo and a girdle kit. just get a 6.5 turbo and manifolds off a 6.5 turbo diesel and install it on your motor. and if you want more speed change the trans to a 700r4 or lift the truck and get larger tires.What do larger tires do and what size?
Jeez, there is nothing wrong with my truck. I want a project and to spend money, but only if it is an improvement.
EDIT- OK, I found it.
That's what I was thinking about.if you want more speed change the trans to a 700r4 or lift the truck and get larger tires
the 6.5 and 6.2 are almost the same motor but the 6.5 has a weaker block, that's why we put turbos on 6.2'sThat's what I was thinking about.
Afraid to ask, but what about those hmmwv engines available now? Are the parts interchangable with the CUCV? I come a long ways from my original 6bt idea.![]()
6.2 Diesel Engine - Hummer, Chevy, GMC!!
Here is the CUCV M1028a2 with an cummins
http://www.steelsoldiers.com/members-rides/51987-cucv-m1028a2-5-9l-cummins-install.html
I dont think you would gain that much with the 5.9.[/QUOTE said:UUUMMMMM.......ya....a stock 5.9 has 215 HP, 75 more horse than a 6.2, turn the fuel pump screw up a couple of turns(free power) and install a #100 fuel plate, about $200 and that will put the 5.9 over 300-350 hp. I think that's a big gain, even stock its a lot more.
[FONT="]I think what he meant is for what he is doing there would be no gain in spending that kind of cash to put a 5.9 in. [/FONT]UUUMMMMM.......ya....a stock 5.9 has 215 HP, 75 more horse than a 6.2, turn the fuel pump screw up a couple of turns(free power) and install a #100 fuel plate, about $200 and that will put the 5.9 over 300-350 hp. I think that's a big gain, even stock its a lot more.
