Cleptomaniac
- 1
- 38
- Tecumseh ,OK
Have you not had time to work on her lately?
when i get time i'll get a picture of exactly what i did. I replaced the upper light assembly with a whole led board from a cheap light, it actually worked really well and as you can see they're pretty bright.Looking good! I guess you put an led conversion bulb in the housing?
Not sure as i STILL havn't had time to get a panel and fuel tank mounted. it does say "hearing protection required" on the sideWhats the sound level from the generator both inside and out when its running?
thanks tm. i linked to the manual earlier in the thread.Awsome fab job. can't wait to see the finished product... keep up the good work .. what's the specs on the s805
