oddshot
- 116
- 43
- Jasper, Georgia
I replaced the boot and seals on the left side of my truck today.
Thanks to this thread I had an idea of what to expect and had the stuff that I was going to use to make a puller at hand ... all I had to do was cut it to fit.
The cross piece is an old steering wheel puller ... I had 2 so cutting down one was no big deal.
The length I cut it down to is 2 1/4 inch. At that dimension it fit against the seal perfectly.
The bolt is from an old harmonic balancer puller ... it threaded into the steering wheel puller so I didn't have to harm this at all.
The bracing piece is just an old piece of 2X5 channel I had in the junk pile. I just had to drill a 5/8" hole in it.
I just stuck the bolt through the brace ... inserted the cross piece behind the seal and held it in place with a finger while I threaded the bolt into it. I tightened up the bolt by hand ... and positioned the brace against the housing. Once everything was in place ... I tightened the bolt with my 1/2" air gun until the seal and retainer popped out. Worked like a charm.
Next week I'll do the right side.
oddshot
oddshot
