I always seem to be loading and unloading heavy objects in and out of my Deuce in situations where ramps or loading docks are not practical. I am considering setting up a truck crane that I can mount on the tailgate when needed. The stuff I lift tends to be small in volume and up to 600 or 700 lbs (maximum - most in the 200 to 300 lb range).
I am considering purchasing this crane:
Pickup Truck Crane W/ Cable Winch
and then beefing it up with a truss up top, and finally replacing the hand winch with this electric model:
12V Power In, Power Out Winch - 3000 Lb. Capacity
I would mount the crane by drilling the tailgate such that the crane straddles the hinge the second from the right. I would add a good-sized steel backer plate underneath, and use good hardware so that I can mount the crane when I need it.
The top part of this crane is removable so theoretically I can close the tailgate with the lower part still attached.
I could also make a leg that extends from the ground to the underside of the tailgate so that all of the weight is not borne by the hinges and tailgate chains.
The nice thing about this is that the components are fairly inexpensive and I can be up and running quickly. I am interested in hearing about potential down sides that either need to be accommodated, or flat make this a bad idea.
To give you an idea of the heaviest item I would be lifting, something like a M37 long block with bellhousing and a civilian truck tranny.
