2600mile recovery :)
trukhead
dane/wi
hi Sean
I looked at your listed route in google map (by clicking on the link) and it comes out to 1200 miles or so.
There are some problems, they are:
The map lists my address as the startiong point and delta as the destination. All of the directions are backward.
To fix it put Delta Pa as the A point, and my address as the destination.
You have a reversal jog at Indianapolis. You backtrack to Dayton and back to Indianapolis.
I reversed to route and came up with 973 miles from Delta to my house.
I called John and said I'd call back at 1:00 PM John's time.
Dennis
seano11
104
Edmonton Canada
Truck blew the alternator less then 2 miles from johns we are gonna try and fix it in the am. Does anyone know if a A1 alternator will work
seano11
104
Edmonton Canada
Fan clutch not engaging
Hey guys which size bolts do I need to bolt the fan direct to the clutch ? I know I should read the tms but using my phone cost me lots,
Scarecrow1
Florence , S.C.
I don't know if I would over ride the clutch that way you are in the cold weather and it may cause you some problems in reaching the ideal temperature .Of course I could be wrong but I would look for a new clutch.
cajun666
Larose, Louisiana
If it work like the ones on m35a3 when put air to it it well turn freely.
Remove air and it turn.
Put you a valve on the hose going to clutch.
I have many buy sensor.
73m819
327
gainesville, ga.
My time looking in the tms is worth something also. I guess you will have to use a computer to find TM questions if you do not want to pay to use your phone to find your answers.
swbradley1
Modertator
1,899
Dayton, OH
If I had an idea where it was in the manuals I'd look it up for you as I know you are 2600 miles from home.....Ron, could you help a brother out?
1,185
Send a PM to mdmorgan, he has them installed in their M936.
I looked in the TMs and did not find where it says to use them, or what size they are.
73m819
327
gainesville, ga.
think thay are 3/8" , I made my comment because you said the reason that you were asking rather then looking up useing your phone because it cost you, didn't say where you were or anything else, other that you DID NOT want to pay a charge to look up stuff in the tms.
swbradley1
Modertator
1,899
Dayton, OH
Thanks Ron. Sean's trip isn't actually starting out on the right foot.
seano11
104
Edmonton Canada
Yup not the right foot at all. Blown alternator cracked fuel line and fan problems. Johns been awesome tho. Does the alternator off the 250 cummins fit on the 8.3 by any chance
1,185
I found one post that said the bolts were "provided". Maybe they are already in the fan hub?
I also found a bunch of threads with either overheat issues or just reading to high temps.
Many point to a Thermal air valve that can be disassembled and 3 new O-ring installed.
You started a recovery thread. This should have been posted there(not in a new thread). You have a bad habit of posting new threads, rather than continue one(you started 2 recovery threads that I merged)
Please try use the forums properly, to get the most out of them.
