Wow !
Sir, that car litterarilly crawl under you CUCV. Is a Hard call as to any potencial frame damage. The 1 ton frame is a pretty stout one, as I also fount out (the one, GOOD thing) the hard way. It may have just shifted the front clipp so as to couse the doors/hood to rub. When looking at damage and the ovious damage for replacements. I would also look at the front springs mounts and bolts, raddiator and mounts as well as the hidro and cooler lines connections, steering box and mounting area, pitman arm and the coulum(?) rod and joint, electrical connections wires and accesories. As it appears that they share ( dissipation, is a GOOD thing ) quit a bit of the inmpact. Saddlly (HOW IT CAME ABOUT) this may Also be a good time to upgrade the tie rod (if not install a cross over steering) with one from O.R.D, OFF ROAD DESSING.com (or other's equivallent ) to a 1 1/2" tie rod , #U9014-HD $115 , U9014-HD tie rods kit, left and right with 7/8 X 18 Draglink ends and jam nuts about $95, #BG05003 Swaybar bushing kit $19, Maybe their Sway Bar disconet KIT GU37001 $99, GM HD draglink links F. & R. (this may be my local GM dealer parts #'s) #88910028 and #88910029 MSRP $63.14 and $58.90. (prices are as of my March 2007 build). Good luck!!
