- 7,422
- 2,528
- 113
- Interlachen Fl.
All I can say is yes this thread is all over the place. Just when I think we are talking about bypass valves, smack me up side the head where on bypass filters. I get geared up on bypass filters and where back on bypass valves. OK I think where on check valves right.
Think we need to start a thread on accumulator's. One on bypass valves and one on bypass filters.
I have been told by manufacture of accumulator's that no check valve would be needed that gears in oil pump should be tight enough to hold back pressure.
I still want to redo the primary filtering and with you guys help I think I am on track.
I see the benefits of a bypass oil filtration system and that could be add to my motor later.
Devilman thanks the B99 full flow has 23 nom.45 abslo. balwin found B7180 full flow 12 nom. 25 abslo. that would fit the filter base VS992 you found. I can live with that for pri. oil filter. Think if I can mount it just a little lower than entrance and exit holes in block I will have a little faster pump up time to the bearings.
