- 827
- 224
- 43
Well, I was torquing the 3rd round a few min ago on the passengers side head which I just got installed, *haven't* done the 3rd round on the drivers side yet.clock your 18mm socket with a pencil. turn it 1/4 turn and it is good. Torque will be off. Depends on how you do it. I would do the 1/4 turn. Good Luck.
I marked all the bolts so I could watch how far they turned. I found that it took 85 ft lb to turn the #1 bolt 1/4" of a turn. The next several bolts were the same... Then it went slightly over 1/4" turn on the #4 bolt, so I stopped and was doing some re-thinking.
So, in the end, I guess the 1/4" turn is the only thing you can do, even though it still seems... "sloppy".
But that's what I'm going to try to do.
Thanks Cucvrus
