Last night after a HOT day at work I was torn between sitting in the A/C or working outside. I decided NOT to mow grass as I was alone. I worked on my trailer project. I need to get it completed and get it up to the vehicle enhancement shop so I can get a title for it. I reassembled the hitch after cleaning and greasing all the moving parts and pins.
![DSCF8613.JPG DSCF8613.JPG](https://www.steelsoldiers.com/data/attachments/627/627378-4f0029fce2ccd325dceb365359e0fd4a.jpg)
The bent-up master cylinder cover looks great. I really like salvaging parts and reusing them. Anyone can use new parts. This is not a new trailer, and it will not require new parts.
![DSCF8614 - Copy.JPG DSCF8614 - Copy.JPG](https://www.steelsoldiers.com/data/attachments/627/627379-684549b57b5da12a225eaf7ac249e6ef.jpg)
I secured and sealed all the connections at the junction box for the wiring. I added a new Grote 4 wire pigtail to run up to the 7-pin/prong/spade round trailer connector. I prefer the 7 pins over the flat 4 even with 4 wires. It holds up longer and stays tight in the plug.
![DSCF8616 - Copy.JPG DSCF8616 - Copy.JPG](https://www.steelsoldiers.com/data/attachments/627/627381-ef42205034a1330c76bb4fcfae0ab4e3.jpg)
![DSCF8617 - Copy.JPG DSCF8617 - Copy.JPG](https://www.steelsoldiers.com/data/attachments/627/627382-03209a5c64ca8334037456642dfbb24f.jpg)
Then I was onto bleeding the brakes. Let me tell you the mity vac is a waste of time. I used it many times, but I choose the ratchet strap.
![DSCF8619 - Copy.JPG DSCF8619 - Copy.JPG](https://www.steelsoldiers.com/data/attachments/627/627384-ee202706f5680122ea7db592a6df5d5e.jpg)
It worked best. Make it tight and bleed. Loosen the strap pull the hitch back out and tighten the strap again. I was able to bleed all the old green/yellow fluid out and get the new fresh air free purple fluid out the bleeders.
![DSCF8618 - Copy.JPG DSCF8618 - Copy.JPG](https://www.steelsoldiers.com/data/attachments/627/627383-9283fca2ad2a92901d6f905d29ebb3f8.jpg)
I refilled the master cylinder, and that job was completed.
![DSCF8620 - Copy.JPG DSCF8620 - Copy.JPG](https://www.steelsoldiers.com/data/attachments/627/627385-0b85fd839cdd61bbd6e3690b357b491b.jpg)
I was on a roll. Just me and my XM radio on channel 313 Rock Bar and I was tearing it up. I jacked up the trailer and put the new tires and wheels on. Looks great.
![DSCF8621 - Copy.JPG DSCF8621 - Copy.JPG](https://www.steelsoldiers.com/data/attachments/627/627386-5db5f6de54eda0b2740757f514dd4cac.jpg)
I will be getting this to the garage for enhancement. Take Care and have a great weekend. I am going to make progress on many things over the weekend. Most no reportable but non the less progress.
![DSCF8622 - Copy.JPG DSCF8622 - Copy.JPG](https://www.steelsoldiers.com/data/attachments/627/627387-77a4acca6375845a2b80b7ffe8c4245e.jpg)
