Dan's M1081 Pick-up and Build
bikeman
503
Ft. Bragg, NC
Dan, the sound is your low air alarm. There's a little "German cross" or "Radiation symbol" looking plastic speaker cover thing about the size of a half dollar just above your steering column, cover that and it will get quieter. It won't turn off until you reach 120 PSI though the whole system. (It will also beep while running if you drop below 120 psi until the air system catches up).... I think it's 120 PSI.
If the red button isn't working, check the wiring on it. Start following the troubleshooting in the TM for "No crank".
Overdrive
97
Wentzville, Missouri
What Shark bait and Bikeman said the alarm is your low air warning... It should shut off when you build up air pressure between 60 and 90 PSI in both tanks. I think mine shuts of in that range.
I would recommend you review the -10 TM on operating instructs for the vehicle. It covers what to expect like the warning buzzer and other checks and safety items for driving these trucks.
All the manuals, -10, -20, -24P are available in the SS manuals forum for A0 trucks.
OD
DanM7890
13
Hickory, NC
How can anybody even think with how loud that alarm gets! My neighbor heard it and came over to see what was going on. Thanks for the heads up about the low air pressure. I will start going through the truck tomorrow as I have a dinner date after work. ;)
bikeman
503
Ft. Bragg, NC
Yeah, it's loud, but it's to prevent dumb private from starting to drive the truck like that and getting in an accident.
Overdrive
97
And its loud so that if you loose air pressure while driving there is ZERO chance you won't hear the warning... I just keep hearing protection in my truck that I throw on initially during warm-up :)
One thing to mention in general, not directed at you Dan ;) , on the alarm as well as other stuff with these medium duty class trucks is be careful to not disable safety features on these rigs. If you get into an accident and have modified required safety features.... Y.I.K.E.S.
DanM7890
13
Hickory, NC
Another issue I'll have to address, I did try to raise the cab manually and the hydraulic fluid came out. I didn't get a picture but I will locate on a TM where and I'll have to rebuild that part. It's located in between the spare and the cab right in the middle.
NDT
7,443
Camp Wood/LC, TX
mkcoen
382
Spring Branch, TX
Been reading them all morning, I'm pretty over whelmed right now looking through 100s of pages.
I printed off just the -10 and it took 2 huge folders and a couple of reams of paper. Obviously there's some stuff in there that you don't have to read and there are a number of intentionally blank pages but the basics are there to help you out. Using the -24p can help identify parts that are either there or give you a good indication as to what's missing. That one takes a little getting used to as you have to find the specific section, identify what you're looking for, then page ahead to find the actual part name that corresponds to the number in the picture. Since I've probably got a couple of weeks yet before I can put my hands on my new M1078 the only thing I can do is live vicariously through threads here and sit and read the TMs.
Oxyacetylene
180
Stoneville, NC
Also been looking through TMs for this missing part. Anyone recognize what's supposed to be strapped there?
definitely the cold start canister. It's available from Napa, part# 33118. That reminds me I need to replace mine (it's empty). BTW, it was good to meet you at the Denton rally. Look forward to seeing this truck!
DanM7890
13
Hickory, NC
Thanks for the PN. It was nice to meet you as well. Since you're local I'll send you my cell # so we can meet up once I get this truck together.
Overdrive
97
No worries DanM7890 there is TONS of info in all the TMs. I downloaded all the manuals from SS but I also purchased a hard copy of the -10 from Amazon so I always have a quick reference in the truck.
I have owned my 97 LMTV since last October and am always learning and figuring out new stuff on how these trucks work. I BIGGEST teacher for me has been simply working on the truck with maintenance and my little custom mods. I know most of the noises the truck makes when driving now like "oh, there goes the CTIS checking and adjusting air pressure" and of course the dreaded 3-2 downshift jerk my truck has when coming to a stop (still working that issue).
OD
