Dan's M1081 Pick-up and Build
DanM7890
13
Hickory, NC
That's the same feeling I have about my M998 because I went through the whole truck taking it apart and repainting it. Now that my M998 is done I'm focusing on this one. I went by the parts store yesterday and got the o-ring, under $3 out the door and I haven't had a chance to put it in yet.
I also have to make an extension for the manual cab lift since mine is missing.
Overdrive
97
Wentzville, Missouri
LOL, I bought that little o-ring even before I got my truck after reading that thread! My cab lift works great but I did notice last time I raised it the little mist puff come out of the hydro unit so I am keeping an eye on it... When you do yours take pics if possible for us :)
Lmtv772
Banned
651
19
Florida
I remember seeing a thread about the unit and how to replace the pump seal, somewhere here before.
DanM7890
13
Hickory, NC
The fluid from the beginning must have been the hydraulic fluid dripping from the seal being broken. I traced it all the way down. I found a couple loose connections by the starter. One looks for an o2 sensor and the other I'm not sure yet.
NDT
7,443
Camp Wood/LC, TX
The O2 sensor looking part is your magnetic pickup for engine RPM measurement. Needs to be hooked up.
DanM7890
13
Hickory, NC
That goop is EVERYWHERE haha. Thanks for the heads up NDT. I had to call it a night because it started to rain so I'll get to it tomorrow.
DanM7890
13
Hickory, NC
Also that second connection is for the troop alarm switch which I don't have. It's connector P39 so that explains why it's unplugged and just sitting there.
Suprman
707
Stratford/Connecticut
Does the truck crank when you jump the 2 big terminals on the relay? When you push the start button do you have voltage going to the relay coil?
DanM7890
13
Hickory, NC
I have no crank right now. I have not tried jumping the two big terminals because that wasn't in the manual. Everyone told me to start following the no-start TM so that's where I started. Is there a way to bench test the solenoid, because I have it removed right now.
DanM7890
13
Hickory, NC
This was one of the first steps, and surprisingly when checking voltage I had more voltage when the button is pressed than what there should be. Almost 30v which makes no sense to me. The manual just says if there's 24VDC present.
Suprman
707
Check all the fluids and jump the solenoid see if it cranks. While you are at it check and see if you have 24v at the fuel solenoid with the power switch.
