From fire truck to MTV
Skyhawk13205
323
Alaska
Took out the front coil springs, this leveled the truck and made for a better ride. A1R only had those spring for future armor so without it, it was overly stiff.
View attachment 934591View attachment 934592
Had a check engine light today, cat et showed a high voltage on the boost sensor. $280 for the sensor and a lot of fighting I got a new one back in.
Finished all the setup for towing the Xterra and took it on a test. Using the 7 pin harness and air brake service line. All lights are functional, the brake activates proportionally with the MTV brake. It also has a breakaway tether to automatically engage the Xterra brakes. A little tough to conbect by myself but normally I'll have the wife and kids around to help.
did you use the M&G brake system, how hard was it to put the actuator on your brake booster, out of all the car towing system this the air brake system on the brake booster seemed the safest and well designed. It would also be nice to be able to use the service glad hand rather than running a line to the brake canister.
  • Like
Reactions: art
aw113sgte
1,423
La Crosse, WI
Used this kit (The universal 2.0 version) https://www.mgbrakes.com/products
Would have like to use the direct mount master cylinder version, but they said it wouldn't fit.
Basically I'm just using the service brake airline from the truck and it feeds into an air cylinder that has a cable connecting to the brake pedal so when I step on the brakes in the MTV I get a proportionate braking force on the pedal in the tow vehicle. It also has a secondary chamber with breakaway so if I pull that breakaway cable, the brakes apply automatically.
20,794
That is a good deal!
Definitely a big plus.
Especially having the breakaway feature...
AND it is even Made in America!
aw113sgte
1,423
La Crosse, WI
Another weekend trip in the books. This one was about 1.5 hours away. Started off by seeing the CTIS constantly trying to adjust to HWY. The front QRV was hissing air, indicating the front wheels valves weren't closing. This caused an imbalance in the front and two rear axles. I just unplugged ctis for the trip. Back home I cleaned out the wheel valve and put in a new diaphragm and spring that was slightly stronger - seems to be working solid now.
Don't have any pictures but the duct going from cab to habitat blew apart on the highway. It was a test fit super cheap hose and I haven't gotten around to finalizing it. Just threw some duct tape on it and continued. Ordered the proper parts when i got back,
Other than those issues, truck did great. It was colder and we were staying for a few days so we used the diesel heater to heat the water(all 4 showering every day) and sometimes to warm the habitat. No issues and worked great! Use 10-15 gallons water for all 4 over 24hours. Do want a different mixing valve for shower, this one works pretty well but doesn't allow for really hot water to pass though.
A number of bike crashes, no fish caught, lots of fires (carry lots of wood on the truck). Campground people were super cool, raced their ATV against my sons bike multiple times. It's an electric bike with DeWalt batteries. They said they maxed out at 25mph and he was pulling away. Another campground we went to, the lady camp director yelled at him saying he had to have a license and be 16 to ride one (both false in our state) - a true Karen.
Systems on the truck worked great, family puts a pretty bid demand on the electrical system - lots of tea, hot water, my coffee, showers, keeping the inside at 72+, charging lots of batteries for the bikes, no issues. Had a lot of shade and clouds but after 48 hours batteries were at 65%.
20241101_174854.jpgPXL_20241101_195742308.jpgPXL_20241101_211605662.MP.jpgPXL_20241101_222843991.MP.jpgPXL_20241101_232333905.MP.jpgPXL_20241102_171423155.jpgPXL_20241102_193405983.jpgPXL_20241102_203302197.jpgPXL_20241102_221207008.MP.jpg
Skyhawk13205
323
Alaska
Regarding your CTIS issues, you might want to think of installing a CTiS off switch, the arctic trucks have them installed and I had to activate mine when it got real cold due to the tires draining when the PCU does a tire check.
Looks like you are having a good time, enjoy your time with your family, these trucks are a tool to build memories. I have taken quite a few trips with my family and the work and time I have put into the truck has been more than worth it.
dlynes
41
Augusta, Georgia
amazing job! love it and I love how much your family were involved and how much use you're all getting from it! beautiful family. did you ever consider building out a floor frame using weldable ISO locks to secure the container?
aw113sgte
1,423
La Crosse, WI
I may do this as we plan to go out quite a bit in the cold. Looks like a simple install.
aw113sgte
1,423
La Crosse, WI
I did, but there just wasn't enough room to fab the structure needed for those ISO mounts - I wanted to keep the box as low as possible and with the battery box and fuel tank locations it just wouldn't work. Having compliance between the box and frame was very important and if using the ISO locations, the allowed displacement would have to be significantly larger than having the compliant mounts closer to the centerline of the truck.
aw113sgte
1,423
La Crosse, WI
Reworked the chassis and cab grounds, that one to the cab was atrocious - paint and the toothed washed wasn't even compressed against the two surfaces. Used a flap wheel and carbon conductive grease for the various connections.
Christmas is coming so threw on some lights. Also put some on the inside.
Sprayed the spring mounts with fluidfilm to prevent rust since I'm in WI and salt is now on the roads.
Installed a durable duct from the have to cab.
Cold weather shield is installed (that thing is a PITA)
Installed a switch to disable CTIS - used a cruise control switch I had laying around, will do something better in the future.
Upgraded the software on the victron system and have been taking measurements. To keep the hab at 50degF in 10-15F weather I'm at 7.2 kwh/24hr. To keep it at 68 under those same outside temps, I'm at 12.4. this is with the mini split. The diesel heater takes a fraction of that.20241206_155604.jpg20241206_155539.jpg20241206_155513.jpg20241206_155448.jpg20241206_155431.jpg
aw113sgte
1,423
La Crosse, WI
Currently out at a frozen lake about 2 hours from home. Absolutely gorgeous and having a wonderful time with the family.
Tried using shore power but their GFCI keeps tripping, I think it's because of the various inductive loads from the autotransformer and inverter. There are different GFCI trip curves and since I'm using the standard 15amp outlet, it seems to have a sensitive one. It will charge for a while but seems to randomly trip. Not a problem with the large battery but I think I will use the RV plugs that don't have GFCI and then use my own. Never trips the GFCI at my house.
Besides that little issue, truck is working awesome.
PXL_20241207_195606532.MP.jpg20241207_152240.jpgPXL_20241207_215832905.jpgPXL_20241207_223040206.jpgPXL_20241207_225104522.MP.jpgPXL_20241207_225401909.MP.jpg20241207_165557.jpgPXL_20241207_225837502.MP.jpg
MatthewWBailey
1,905
Colorado
Theirs is probably just defective. The RV park and outdoor pedestal GFCI's are exposed to lighting induced surges and more extreme temp swings than interior mounted units. Plus they're probably old. Inductive loads should not trip a GFCI even though there's a lag between I and V. GFCI's measure zero sequence current, a fancy term for ground short. It ignores phase angle between I and V. I get asked this a lot on people's old fridge tripping a garage GFCI. It's usually a short in the winding or bad GFCI.
aw113sgte
1,423
La Crosse, WI
This is what I am referring to, but haven't looked into the details too much.
I tried another GFCI on the pedestal with same results. Sometimes charges for and hour, of sometimes trips in a couple minutes.
aw113sgte
1,423
La Crosse, WI
MPG report
30400 lb weight
Eco hubs
6x6 m1096 (lwb chassis truck)
2007 C7
188 miles driven
30.3 gallons
Highway speed was 65, that was for about 90 of the miles, rest were 30-55 backroads.
Elevation along route:
= 6.2 MPG
aw113sgte
1,423
La Crosse, WI
Took a little weekend trip to a nearby RV park. Only one other person there. Lots of trails and areas to explore. Shoveled off the pond to make the kids a hocky rink - they spent hours out there.
Truck did great, I did plug in to 120V as the wife likes the relaxation of not having to worry about the battery level at all. She likes to keep the temp 75+ inside so that takes a bit. Heat pump works well, but for rapid heating (and so everyone was warm when getting out of the shower) the diesel heater can really put out the BTUs. Had it at 80 in there during shower time.
I do want to put some more cabinets on the walls as we could use a little more interior storage.
I do need to get a solution for the vent fan. Right now I'm using the fan that goes to the cab, but that means the humidity is pushed up there. Had some ice forming on the inside.
Last trip, I was tripping the pedestal GFCI, this time, with no changes I didn't at all. I really think that other one was a bit flaky.
Another great trip making some great memories with the family!
20250112_081051.jpgPXL_20250111_234334346.MP.jpgPXL_20250112_152420677.jpgPXL_20250112_170241141.MP.jpgPXL_20250111_195624833.jpg
aw113sgte
1,423
La Crosse, WI
A few weeks ago, I got a truck for the next build. Had a good time with the FMTV, figured I'd make another camper conversion, this time at a slower pace.
It's a MTVR, mk23. Cat C12, 28klbs unloaded, 30klb payload, 6x6 with differential lockers, independent suspension, 16r20 tires, CTIS, 14ft bed length. Should be a fun build!
MatthewWBailey
1,905
Colorado
So, what you're saying is that in 2-2.5 yrs, the next one will be a 10x10 HEMMT "RV" project?
aw113sgte
1,423
La Crosse, WI
Have had some exceptionally cold weather today. Made for a good test of the mini-splits heating. It is constantly maintaining 50F in the truck to prevent any water freezing.
It maxed at -16F today and the Fujitsu Mini split (9kbtu) had no issues maintaining the 50F. I did get the low temp capable model- AOUG09LZAH1 https://www.fujitsugeneral.com/us/products/split/wall/09lzah1.html Over a 24hr period, the truck used 16.8kwh (almost all of that is to the mini-split).
Averages in December (about 40F-20F it uses around 4-8kwhr/24hr).
I didn't try upping the temp to a more reasonable 65-70. Not sure it could have done that, but that's also why I have the diesel heater.
Overall very happy with the mini-split, just wish the idle draw was lower (never drops below 50W - but I can shut power off to it if I want).
The inverter preferentially pulls from the shore power, hence why solar is so low (also winter and cloudy).
aw113sgte
1,423
La Crosse, WI
Had another weekend trip about 2 hours away. Temps into the teens - high of 40 the second day. Truck worked great and didn't have to do anything to it so got to relax and enjoy the family time. Plan to recline the stock seats a bit as it can get a little old on the back after a while.
The tire balance is such a strange thing, the day out the truck was smooth as could be (and the truck had sat for over a month so I would expect there to be some flat spots) but on the way back it would oscillate at times. Really seems to be when the tires get in a certain phase with each other. Pretty minor overall just kind of strange.
PXL_20250222_180903954.jpgPXL_20250222_200810108.MP.jpgPXL_20250222_212455136.jpgPXL_20250222_221853493.jpgPXL_20250222_233155649.MP.jpg
