From fire truck to MTV
aw113sgte
1,423
La Crosse, WI
Another weekend trip in the truck. Finally got around to installing cruise control and makes the trip a lot more enjoyable. These switches fit the cutouts perfectly.
Also installed a vent switch so I can either pump air from the habitat to the front cab (for pre-warming or cooling) or to the outside (for when taking showers).
PXL_20250328_213651446.jpg20250328_182540.jpgPXL_20250328_214828192.MP.jpgPXL_20250328_215614345.jpgPXL_20250328_225820594.jpgPXL_20250328_230823391.jpgPXL_20250329_125526357.jpgPXL_20250329_141608235.jpg
aw113sgte
1,423
La Crosse, WI
@aw113sgte love it! thanks for updates and sharing! Any need to add a protective covering over your minisplit's to fan blades?
It would be a good idea, just haven't gotten around to it yet. I'd like to have a shield both to prevent branches getting in there, but also it's a wind block so the fan is not getting hit by 70 mph wind for hours when on the highway.
aw113sgte
1,423
La Crosse, WI
Another weekend out making memories! Highlight was the trout stream.
Noticed cruise control doesn't let me increase or decrease speed once engaged. Normally clicking set/resume would increase and decrease speed by 1mph but this didn't work. Holding seemed to error out cruise and had to cycle the cruise switch to get it to work again. Guessing this is just me not knowing how the switches are supposed to function.
Skyhawk13205
323
Alaska
I installed cruise control on the 3126, I wired in a service brake input using a change over relay, and I had to figure out the cruise control set resume polarity in relation to switch and ecm. If you have CAT ET, you can live view what position the set/resume is. On my truck when the cruise control is armed I can set my speed and increase or decrease the speed using the set/res switch. Hitting the brake disengages the cruise control but it remains armed, pac brake is also inhibited when cruise control is armed. Since yours is a C7 the logic might be different.IMG_7078.jpeg
aw113sgte
1,423
La Crosse, WI
I installed cruise control on the 3126, I wired in a service brake input using a change over relay, and I had to figure out the cruise control set resume polarity in relation to switch and ecm. If you have CAT ET, you can live view what position the set/resume is. On my truck when the cruise control is armed I can set my speed and increase or decrease the speed using the set/res switch. Hitting the brake disengages the cruise control but it remains armed, pac brake is also inhibited when cruise control is armed. Since yours is a C7 the logic might be different.View attachment 944758
I have cruise/set/res wired correctly, and cat see cat ET registers all 3 switch positions correctly. I wired a relay to cut the cruise on circuit when hitting the brake. All that works as it should...just can't seem to adjust speed while in CC.
Piatheem
California
Hello, do you happen to have a diagram on how you wired the switches? Thank you.
Skyhawk13205
323
Alaska
So is ground just a battery negative or pin 5 on the ecm?
I used sensor common, there is some difference of opinion that sensor common is not the same as gnd, but it seems to work for most people. I also had to wire in a relay tied to service brake to give the ecm signal the brake is applied to shut off the cruise control.
aw113sgte
1,423
La Crosse, WI
Haven't been doing any modifications to the truck, except added an exterior fresh water tank connection. Been going on lots of adventures though so it's photo dump time. PXL_20250524_225645267.MP.jpgPXL_20250531_193554842.jpgPXL_20250531_225713026.MP.jpgPXL_20250627_184448968.jpgPXL_20250703_190919057.jpgPXL_20250703_232003669.jpgPXL_20250705_220145692.jpgPXL_20250705_225006113.jpgPXL_20250706_022809465.jpgPXL_20250706_171214574.jpgPXL_20250706_192222858.MP.jpg20250518_125314.jpg20250628_200352(0).jpg20250704_164931.jpgPXL_20250524_183436965.jpgPXL_20250524_193736368.jpg
aw113sgte
1,423
La Crosse, WI
Was having some reduced power issues, occasional check engine light (no codes stored) turned out to be a failing atmospheric pressure sensor. Notice it's reading 7 psi (we are at less than 1000ft elevation so should be around 14.7). Unplugged the sensor for the drive back home and had reduced power - cat et was flagging "EGT overtemp derate" I'm guessing due to that sensor being unplugged caused that as it wasn't there before. New sensor $250. Already had the boost sensor fail a while ago, but due to the price I didn't replace the atmospheric sensor prophylactically. I'm sure @GeneralDisorder is saying "I told you so" :)
aw113sgte
1,423
La Crosse, WI
Now for the non-technical. We've been taking the truck out every weekend and making great family memories. It's rare to find something everyone loves, my wife loves comfort and being away from the chores. The boys love finding new friends to play with. I'm happy they are happy and proud something I built bring so much joy to the family.
These pictures are all from our adventures in the past month or two.
dlynes
41
Augusta, Georgia
my truck's TIM throws the error, "Atmospheric: transducer reading out of normal atmospheric range". what range is normal? my Cat ET has mine with a value, min and max of 15 psi.
aw113sgte
1,423
La Crosse, WI
You probably have a failed sensor or wiring. When the ECM detects an error, it just assigns a value of 15 (14.7 psi normal for sea level). It did this when I unplugged the sensor. Definitely ran worse than normal when that sensor was unplugged.
Piatheem
California
Where did you find the matching butons?! I searched everywhere for those!
