just brought home a 82 cucv from jersy
dstang97
33
Clover, SC
I am not sure exactly where it is located...but I think there is a vin also on the frame some place. If you can find that it is probably the real vin and you can see when your truck was truly built.
I have never found a vin stamped on a frame. I have taken apart numerous c/k trucks
linx310
texas
From what I recall reading they do have a VIN on the frame. It is located on the top part of the frame, either on the driver or passenger side near the doors and you may need a mirror to see it.
I am gonna go see if I can find mine....
NICK_M1009
Brown City, Mi. (The Thumb)
One more option. Go to members rides on the main page, look at 2011 vin info. If your truck has identification numbers on the bumper and tailgate you can get ahold of CARNAC and maybe he can make some sense of all this.
SmokeyDod
Easley, SC
Cucvfreek, When you found vin #, was it on the outside or inside of frame & which side? Driver or Pass. side? Also was it it complete 17 digit vin or just the last 6 numerical #s which denotes only the "serial #" part of the vin which is the number of the frame that goeswith the "cab" of the truck. And you stated it is on side of frame and not on the top side of the frame. This would help.
Cucvnut
72
Carver, Oregon
Smoke, It was on the passenger side about midway in the door only the 6 vin numbers.
SmokeyDod
Easley, SC
CF, That's what I found. It's where the frame starts an angle down. GM started putting them on the trucks & blazers during that time and the the last 6 digits are sequencially numbered. I don't think there is any bed related number, so as long as you keep the cab on the orig. frame, you should never have any vin. # problems with DMV.
Nick, get you a flashlight and a dental mirror and look in area we are talking about and you will find the last 6 digits of the vin. #.
SmokeyDod
Easley, SC
Another way you can ck this #, is to first feel with your fingers on the top of frame until you feel the numbers. Then get you a pc of paper and lay it on top of the numbers, then with a pencil, rub it across the number area and you should be able to see the numbers stamped there.
jdemaris
after searching craigslist for a while i found this truck un jersy for 1500 bucks the glow plugs and starter were rewired to 12v it needs new brake lines witch i did and replaced batterys it starts great it leaks tcase fluid but ill figure that out when it warms up
All trucks sold in model year 1982 have unique fuel injectors that will not fit any later 6.2 ever made. The threads are different. Also all 1982 6.2 diesels have red engine blocks. 83s and later do not.
1984 was supposedly the first model year for military rigs. Something sounds fishy. Who know? Maybe a few early ones were unofficially purchased just to try?
Read the ID tag on the fuel injection pump. I have the entire list that I got direct from Stanadyne. It does not show any 82s or 83s for the military.
Here's the list for all pumps made for 6.2s from 1982 to 1984.
DB2829-4090 14050587 1982 LD C/K Truck C/K DB2829-4126 Note 1
DB2829-4091 14050588 1982 HD C/K Truck C/K DB2829-4153 Note 1
DB2829-4126 14050587 1982-83 LD C/K Truck C/K — —
DB2829-4127 14050526 1982 LD Truck - ALT. C/K — —
DB2829-4151 14061645 1983 P Truck (Motor Home) C/K — —
DB2829-4153 14050588 1982-83 HD C/K & P Truck C/K — —
DB2829-4187 14066280 1983 LD & HD C/K Truck - ALT. C/K — —
DB2829-4188 14066277 1983 LD G Van G — —
DB2829-4189 14066278 1983 HD G Van G — —
DB2829-4190 14066279 1983 LD & HD G Van - ALT. G — —
DB2829-4266 14077133 1984 P Truck (Motor Home) C/K — —
DB2829-4267 14077179 1984-85 CUCV (Military), HD C/K, D Truck C/K DB2829-4520 Note 2 except (d)
DB2829-4268 14077135 1984 HD G Van G — —
DB2829-4269 14077136 1984 HD C/K Truck - ALT. C/K — —
DB2829-4270 14077137 1984 HD G Van - ALT. G — —
DB2829-4274 14077168 1984 LD C/K Truck C/K DB2829-4425 Note 3
DB2829-4275 14077171 1984 LD C/K Truck - ALT. C/K DB2829-4426 Note 3
DB2829-4276 14077169 1984 LD G Van G DB2829-4427 Note 3
DB2829-4277 14077170 1984 LD G Van - ALT. G DB2829-4428 Note 3
DB2829-4305 14077134 1984 CUCV (Military), HD C/K, D Truck C/K DB2829-4267 Note 4
DB2829-4309 14077185 1984 LD C/K Truck - CAL. C/K — —
DB2829-4310 14077186 1984 LD G Van - CAL. (Man. Trans.) G — —
DB2829-4355 23500014 1984 HMMWV (Military) C/K DB2829-4471 Note 5
DB2829-4366 23500077 1984 LD G Van - CAL. (Auto. Trans.) G DB2829-4439 Note 5
DB2829-4386 23500256 1984-85 CUCV (Military), HD C/K, D Truck - 1.2 cSt C/K DB2829-4521 Note 2
jdemaris
There were no 1987 made in 1987 that is know off likely due to the factory shut down for the new 1988 model year design to re-tool the plants.
I've got a model year 1987 diesel Suburban made Jan of 87, and a model year 1988 diesel Blazer made in Sept of 1987.
Production numbers for all diesel Blazers made by GM, civilian and/or military.
1982 - 9438 diesel Blazers
1983 - 7176 diesel Blazers
1984 - 4230 diesel Blazers - also first 23,000 military diesel Blazers
1985 - 2100 diesel Blazers
1986 - 1260 diesel Blazers
1987 - 310 diesel Blazers
1988 - 270 diesel Blazers
1989 - 230 diesel Blazers
1990 - 160 diesel Blazers
1991 - 92 diesel Blazers
coyote_hunter
Kansas
I doubt a 2wd cab was put on a 4wd truck. I put a 86 2wd cab onto an 85 4wd and the floor humps are not the same (had to plasma both humps out and swap them). The 2wd cab will interfere with the transfer case. My guess is that they swapped vin numbers, I did this when I swapped my cabs.
ranchhopper
139
south elgin illinois
(QUOTE)1984 was supposedly the first model year for military rigs. Something sounds fishy. Who know? Maybe a few early ones were unofficially purchased just to try?
DB2829-4386 23500256 1984-85 CUCV (Military), HD C/K, D Truck - 1.2 cSt C/K DB2829-4521 Note 2[/QUOTE]
Not necessarily true this VIN plate shows my 1009 was built late 83 but if a truck was built in 82 it should be stamped into the plate like this one..
