bikeracer917
- 0
- 0
- jax, florida
Need help with the single black wire for the fan cutoff. Does it just wire into the ground lead of the dash switch for fording? Anyone know???
Thanks for posting this info. I just checked mine and there is evidence of the clutch bolt heads rubbing the pulley when the clutch is disengaged. I couldn't find any details for the referenced spacer. I can probably fab one, if anyone has the details on the thickness that would be appreciated.Here's something to be aware of when adding AC:
https://www.nsncenter.com/Library/PSMAG/PS_722?PageNumber=7
I don't think it was the cause of my fan clutch imploding but there was signs of minor contact between the bolts on the back of the fan clutch and the face of the AC pulley.
I'm trying to get that info now. The person that passed the article on to me is checking and I had specifically asked him about thickness thinking I'd need to make my own.Thanks for posting this info. I just checked mine and there is evidence of the clutch bolt heads rubbing the pulley when the clutch is disengaged. I couldn't find any details for the referenced spacer. I can probably fab one, if anyone has the details on the thickness that would be appreciated.
Nope I'm out of those at the moment.Hey scottmandu? Do you have the correct idler pulley? My engine is the c7
Hi DaveGents-
A few years ago my company used to install very high quality German 24VDC rooftop A/C units (on specialty trucks buses) and we had very good luck with them (the units and manufacturer support). Installation is super quick and easy...basically, cut hole, mount unit and seal, run 2 wires, turn on - a bit over-simplified, but complete installation in 3-4 hours. At 24V they provide 12k BTU/250 CFM @ 60A (70Lbs). All controls are on the cab ceiling - in reach of driver and passenger. Parts are readily available, exterior and interior housings can be painted. Units fit into turret rounds. We are going to start importing units again, but this time in 12VDC for a different application. I can add 24V units to our orders if there is interest, particularly from this group. NOT looking for any commitments, but LMK if you'd have interest or if you have any questions. Complete units would be about $1950/each. Some pix and dims attached.
Thanks,
Dave
View attachment 643294View attachment 643295
