Looking for recommendations on Injection Pump rebuild in the Ft. Worth area
85CUCVtom
26
Lakewood, Ohio
I little off topic, but I'm trying to remove the valve covers while I have the opportunity and paint them. I've got the bolts out, but the covers are glued down tight with what appears to be orange RTV sealant. I've tried hitting them with a rubber mallet but don't want to dent them. I haven't found a good place to try to pry with a screwdriver either and don't want to bend them. Any suggestions? On a side note, I got a call this morning that the pump is done and is on it's way back.
Can you get a little pick or pocket screwdriver under the edge and start to work them loose?
Jack Lope
TX
They're on pretty tight, but I guess this is what I'll have to do, just keep working at it. I don't know how solid they are and don't want to be too rough and bend them out of shape any. I think the screwdriver I was using was too big. I need try a thinner one.
cucvrus
10,505
Jonestown Pennsylvania
Carefully cut under the edges with a utility knife. Work it in and out a couple times. They will come loose. Sort of a shame to disturb them if they are that tight and not leaking. But do as you wish. I would do it also. Good Luck. Be careful and wear gloves so you don't cut yourself. I have kevlar gloves that I wear when doing metal work on tin and sheet metal.
Jack Lope
TX
I'll admit, I've considered putting the bolts right back in!
Jack Lope
TX
Just tape off the engine and paint them in the truck if you have too.
This is what I ended up doing today. It's not as good as if I could have removed them, sanded and painted properly, but it is already a nice looking improvement. Since I already took the bolts out of the valve covers, I'm hoping I didn't open a can of worms. I need to go look up the bolt pattern and torque specs for the valve covers and hope that they stay as sealed as they had been. I'm hoping so since I haven't been able to budge them even with the bolts out.
cucvrus
10,505
Just put a little sealer on the flange bolt/studs and install them. No sequence that I know of. Just use a 1/4" ratchet and go at it. I don't torque rocker covers. Really. If I were building a space shuttle I would think about it. But these old engines. Rocker covers tight/done.
Jack Lope
TX
I received an injection pump today. It's not the one I sent out, though. I thought they were rebuilding the one I sent, but it seems it's just an exchange. What do the codes mean on the tag? I thought the "J" on my old pump meant J code for the CUCV's. The new pump has "SH". Is this a civilian model pump?
cucvrus
10,505
Sometimes during the rebuilding process the pump housings are not rebuild able. I never wrote any numbers down on the pumps I sent. I just sent a core pump and received a rebuilt pump back. The pump will be fine. It will work. I do not think there is anything special from a C code pump to a J code pump. I never came across any issues using either. Do you have new intake gaskets for the J code engine? Are you ready to install the new pump?
cucvrus
10,505
The J code is the engine assembly. I was not aware that the injection pump was anything different. As a matter of fact I thought the military injection pumps were turned down and had less power then the civilian pumps. That was my understanding. Going forward lets just get the injection pump on and I am sure you will be pleased with the results. Every injection pump I ever installed and others I know installed were smiling after the first test drive. Injection pumps die at such a slow rate you don't notice how they poorly run. When you get it started with the new injection pump timed and all set up you will be pleased. I am very sure of that. How sure 99.99/100% sure. Let me know if you need any help. Others can help also. CUCVLOVER just put one on his and was happy with the performance after words. Good Luck. You are over 1/2 way.
CUCVLOVER
Just set your timing marks and call it good. I did not look to see if my pump even had numbers. I don't know if I got the same casing back and I don't care 1 tiny bit. My truck runs awesome and has plenty of power. Leave the hood shut and run the donkey water out of it.
I set my pump back to how it was timed which was the marks perfectly lined up.
Good luck with the install.
Chaski
56
Burney/CA
Glad to hear you are going to put the pump back on. Hopefully you marked or measured your timing marks before you pulled your pump. Correct timing is usually not having the marks alligned. The pump mark should be offset to the drivers side. If you download "The 6.2 Liter diesel engine" GM training manual 16015.05-1C there is a nice illustration (4-166) on page 4-99 that shows that the correct adjustment range is an offset of 2.5-4mm tward the drivers side (exact offset depends on your pump model).
Keep that in mind if you did not mark, measure or take a photo of it before you pulled it. If your timing is too retarded it will be difficult to start when cold. Turning the pump to the drivers side advances the timing, passenger side retards it. You don't want to advance it too far. My engine seems to like the 2-3mm range.
Jack Lope
TX
Hmm... The only marks I checked before removing was the transmission vacuum device bolts.
cucvrus
10,505
You will be fine. I never done anything but line to line for 20 years. I always have running trucks. I have 8 CUCV's at my place all line on line and 5 at work all line on line. I must be doing something right. If I was wanting to get technical I could take them and get the timing checked. But I watched them do that they ended up line on line. IMHO you are good to go. I have seen a few that were line thickness over the line towards the drivers side. When I put the new pump on they were fine line on line. Lets not put an unneeded scare into this man. I see it as being fine. CUCVLOVER how does your run? And where do you have yours timed? Share it as a positive reinforcement and encouragement. Please. Jack Lope the force is with you. Just go put it on and all will be well.
CUCVLOVER
Mine is set line to line and runs like a champ.
https://m.youtube.com/watch?v=ax-Yi4Gv7ys
This is a video I made the other day.
Chaski
56
Burney/CA
Mine starts and runs too. It even starts right up when it is 20 degrees outside with no excess cranking.
If you do want to look at 16015.05-16 it is in the TM section right here on Steel Soldiers.
Jack Lope
TX
Thanks for the info everyone! I'm starting the reassembly process Thursday (tomorrow) morning. I figure I'll start with attaching fuel lines to the pump. Any tips regarding that?
cucvrus
10,505
Use a 16mm line wrench and make sure they are tight. And make sure they are in the correct order. Turn the pump so it lines up with the gear and bolt holes the first time. I will monitor my emails if you have any questions.
