I managed to get the right rear mount in place.
This is the right rear.
The left mid cargo area without the mount. Now with the mount and bushing in place.
Both cab mounts. Like I said oil and grease and run the bolt in and out a few times. Get it so you could install it with fingers. Avoid stripping and cross threading the caged nuts. You will be happy you did get them clean and easy to tighten.
I did more work on the M1009, mowed all the grass and worked on another project. I am tired. Be Safe and Take Care.
I looked underside and hooked up the linkage to the transfer case. I noticed that the speedometer cable just swings in the breeze,
and I added a rubber coated P clip and fastened it to the bolts thread from the center cover.
Nice and secure now like it should have been from new. Take Care.
Bolt placed in from the inside and the nuts go on the outside.
I need to study all the brackets and figure out how to reassemble. I got it. I need to wait to complete the assembling till I get the lifting/tie down tubes painted. I figured it out. It was like a puzzle. It only aligns one way so after I figured it out it went quick.
Take Care I hope to get more done tomorrow. I need to get the bumpers installed for alignment and bracket adjustment only. Then I will remove them again for the entire body repaint.My Son got that for me as a Christmas gift. I never need anything bigger than that. If I do I have other issues. I fixed a lot of bent stuff with that bar. It is a Snap-On I never ask what he paid for it. I had a prybar I made, and he never liked it because I was always slipping off with it.Damn nice pry bar !
I found enough clip nuts and bolts to assemble eh front inner fenders.
I ran them all thru a tap and die and am ready to assemble the inner fenders. Next, I need to locate a set of D ring tubes so I can sand and paint them. I put the inner fender clip nuts into the right fender and moved onto another project. I will get back at it tomorrow after work.
Take Care and Be Safe. More Later..We have all had days like this. I started out putting my tools away and as the day went on other things came to mind. I did get all my tools put away and the shop floor is swept clean. Then I thought I would try and find a few inner front fender nuts; I know I have them but where? I dumped out a few old fastener boxes and began to strike it rich. View attachment 874717 I found enough clip nuts and bolts to assemble eh front inner fenders. View attachment 874718 I ran them all thru a tap and die and am ready to assemble the inner fenders. Next, I need to locate a set of D ring tubes so I can sand and paint them. I put the inner fender clip nuts into the right fender and moved onto another project. I will get back at it tomorrow after work. View attachment 874719 Take Care and Be Safe. More Later.
This is the 4 tubes with extra parts attached. All separated and the front brackets that I had powder coated 20 years ago.
The parts on the left are all extra parts.
I have been sorting and that helps find things a bit quicker. Working 10 hours on my FT job makes me tired but as long as I make slight progress, I am OK with that. Now to get these parts back in a bin so I can locate them if anyone else or myself ever need them.
Thats a wrap for the night. Take Care and Be Safe.
Sometimes you have to spend things other than money. Time well spent.
I remember when I bought my first CUCV back in 1995. Everyone said the ballast resistors went bad all the time and that they needed bypassed. So, I saved and bought everyone I ever seen. After 25 years I never had one go bad. I call BS on that. Most times it is some other issue or modification that causes the issues that the resistors took the blame for. Anyway, I have a few of them. Cowl screens. The 1984 cowl screen is different than all the others. This is a 1984
The reason the stem holes are smaller is because 1985 GM trucks were equipped with wet arm wipers.
I will use the 1984 cowl screen to keep it correct for the year. It has to be one that requires the most sanding. Be that as it may. I can do it. OK. I have all the parts that need sanded spread out before me. If you get bored and want to help, I have left and right-handed sandpaper.
The 3 M8 valve cover studs that got thrown out by the neighbor.
Take Care and thank you for looking. Good Luck on your projects. I must get back out there.
I removed the plastic sheath and sanded the rod that rides inside the plastic sheath till it was smooth and the plastic spins freely on it. I am going to paint the rods but not the area that the sheath fits into. That area I will thoroughly grease during assembly and after paint.
I promise that the cleaning and lubing of the gate hinges and the torque rods will have a positive effect on ease of opening and closing that M1009 tailgate. I have a full day of real full-time work so I will be limited to my CUCV project. I want to get the rest of my parts sanded. Take Care and Be Safe.
I know where there is one that the broken one will work perfect.
Won't matter for this wall hanger.
I wanted to sand 2 sets for my last 2 builds. I hated to see the silver one that had 5 coats of paint on it.
I looked around in my stash and found another set with the factory paint. Sands easy with 180 grit. Take Care.
Brand new cab mount base washers, excellent used ones.
Keep in mind I was stripping CUCV's in 1995 and stashing parts from the ones I didn't repair. I was picky back then. I found another upper grille trim piece. I need one for my last build.
I found these nice OEM under fender inner fender splash guards. And I found the newer model front D ring tubes.
The older on early models is the crushed one because it had not crush tube inside. I sanded enough for 2 units. I think the stored one has all 4 tubes still attached. I am prepared.
Sanded and ready for sealer and paint.
. Now onto the Grille.
The paint is really nice so I will just scrub it and sand it with 180. I sanded it and scrubbed it really well.
Nice and clean.
So clean it received Gold Bowtie of excellence.
Then onto the brush guard. I am tired of sanding for 1 day. I will get that next time.
This was my home-grown winter front.
4 bolts and the cover were off. Then 4 J bolts and the cover bracket was off. Agin a nice clean freshly CARC painted brush guard. Nicer than most I see. I will scuff it and re paint it with the 383-water base CARC. I am happy with the progress and the heat has let up for now. I am not working at The PARF this year so I can make progress weekly here on the M1009. I have wheels to sand and paint, and I was in horror at the price of 6 new tires. I am staying the course and doing it like it is supposed to be done. No generic tires with white letters for this truck. German M1008 was I able to get black wall tires for the BIAB1? I don't remember. But I am thinking the Goodyear MTR Kevlar in 31X 10.50X15 will make it look great . Take Care and Be Safe. I have a lot of work to do here.
