M1031 pto dash light
sebaeb
sidney/oh
I googled the part # from the TM'S and a place called ralph's came up and says it has them so they are emailing me a picture to confirm and hopefully will have one on order today
sebaeb
sidney/oh
Found a supplier here in ohio, switch should be delivered to me on tuesday, so off to another project till then!
sebaeb
sidney/oh
Is the drive indicator switch picture posted in post #36 suppose to face the fire wall?...is there a rod or something suppose to strike the round actuator when tranny is engaged in drive?....if so mine has been rotated and isnt near anything....lots of work ahead but i will get this generator working one way or another!
thanks steve
Keith_J
1,325
Schertz TX
Back to the camera for the transmission switch :deadhorse:
Yes, Steve, we WILL get your generator working.
ETA PICTURES!!!
First is in park, second in drive and third in 1st or low.
sebaeb
sidney/oh
Installed new TC switch today, ran jumper wire from PTO switch to Drive indicator switch just to bypass the factory wire cause i had doubts and was hoping the wire was bad, but no luck PTO light still stays on unless i pull the blue knob to engage the pto...everything is wired normally open as per the TM'S....keith_j, you are the only one ive seen with the black normally closed switch...that has me confused...Could a bad Drive Indicator switch be causing my Pto light to stay on?....im guessing not....but i wonder what would happen if i swapped out a normally open switch for a closed switch?...kinda makes sense cause the light goes out when the blue knob is pilled out to engage PTO???... im open to suggestions at this point
thanks steve
Keith_J
1,325
Schertz TX
Test the switch. With the PTO knob pushed in, the switch should be open. It should close when the knob is fully pulled. Disconnect the switch before checking to rule out a short to ground somewhere else.
sebaeb
sidney/oh
switch tested fine when PTO knob pushed /pulled...i still cant help but wonder change out the switch and trying a normally closed switch?...would'nt that cause the light to be out when knob pushed in then light on when knob pulled out?
sebaeb
sidney/oh
Does anyone know what voltage should be going to the Governor Actuator via wires #9 & 10?...wanting to check and see if gov . actuator is functioning or not...does'nt seem to be
thanks steve
Keith_J
1,325
Schertz TX
The voltage to the actuator varies to keep generator speed constant despite load. The fuel solenoid is on the injection pump, the pink wire. When the transfer case is in any gear but neutral, current flows as normal to the solenoid. When the transfer is in neutral, current flows through the relay in the box. If the generator over-speeds, the relay switches causing the solenoid to shut off fuel to the engine, killing the engine.
sebaeb
sidney/oh
Got the generator running and working today....next step figure out the parts missing from the air compressor and get it working, its been a good weekend!
Thanks to all who offered advise it was very helpful
steve
