The voltage to the actuator varies to keep generator speed constant despite load. The fuel solenoid is on the injection pump, the pink wire. When the transfer case is in any gear but neutral, current flows as normal to the solenoid. When the transfer is in neutral, current flows through the relay in the box. If the generator over-speeds, the relay switches causing the solenoid to shut off fuel to the engine, killing the engine.
