M146 Camper
olly hondro
592
tucson AZ
Haven't found a '146 yet, though have seen the windowless version of that trailer. I s'pose I could install the windows from the 109 box (not have as many) but that sound like alot of work 8<(
that is the first i herd of a that so i was wondering what the name of it was but
th other 6 ton i think you are talking about is the M373.
olly hondro
592
tucson AZ
I'll get the number off it next time I'm over there, The owner uses it for storage so it isn't for sale. Its a 6-ton , single axle, 9.00x20's like you say.
Trailboss
140
Norwood LA
I have an M119A1 that I use to haul and store about 115 square bales of hay. Still watching GL for a M146. It has 4 plus 1 spare Deuce rim 9.00x20 tires, rated for 6 tons. Only two rear doors, no side door.
thisbenguy
Wilmington, De
Quick update. Got the ceiling painted, lights up, 24v light painted and up, and started paintin the sides. I am going to use the desert tan but the metal pieces on the door latches and the screens are goin to be painted 24087 semigloss. I feel like it is coming together very nicely. What do you guys think??
I see that the green boxes in the ceiling are what appear to be a red and white light. What other functions do they provide?
USAFSS-ColdWarrior
Chaplain
6,305
Trailboss:
I see you're dragging your trailer with a 5-ton. We are considering a Tractor/Toter for the 220KAK semi-trailer that we just acquired....
Could you answer a DIMENSIONAL question for me please?...
I see that your trailer frame has a DROP just aft of where the 5-Ton's chassis ends. What's the clearance with the 5-Ton's tail?
Our Trailer has 72" (6') from the kingpin to where the trailer frame and body drop to a lower elevation. Will a 5-Ton have enough clearance under there, or should we be looking for a Tractor with a Fifth-Wheel closer to its tail?
Thank for you assist on this.
John
