davidkroberts
- 23
- 38
- west tennessee
well i installed the 395/85/20 michelin tires today went really smooth except for the lip on the stock lock ring is too long it only needs about a half inch. i included a pic of both. the shorter one is the only one that will fit on the thicker sidewall on the 395's. If you use the stock ones you will have to remove about half of the longer flange or it wont mount. You will be able to get it about 3/4 of the way mounted then you will flat run out of room.
I used the stock wheels, tubes, and flaps. I also mounted the rears without flipping the hubs. I personally think it looks better. If i was going to do it again I would mount the tires with 11.00 or 13.00 tubes. The stock ones worked fine but given the chance I would have done it differently.
the ride home was great, very little tire whine. The truck pulls and stops well. The steering is very much improved for some reason. I figure i gained somewhere around 10 mph.
