M35A2 transmission problem
SeldomSeenSlim
Cochise County, Arizona
Thanks Tom. There's a diesel shop over in town. I'll see if one of those guys can take a look for me. Or even better, fix the dang thing.
I did see a transmission takeout for sale a few hundred miles away for $750.
Woodsplinter
Phoenix/AZ
Hey guys, since all the experts are here together I have a question:
I bought my A2 in March and it has always been difficult to shift into 2nd.
This occurs when starting from a stop. (Yes I've read the pros & cons of doing this)
Sometimes I need to let the clutch out (while in neutral) then put it back in to be able to get into 2nd.
Just wondering if this is normal for a deuce. All the other gears shift fine.
Thanks!
Mark
steelandcanvas
87
Southwestern Idaho
Thanks!
Mark
I'm far from a tranny expert, but it sounds as though your second synchro might be a bit worn.
m-35tom
226
eldersburg maryland
if you mean at a complete stop, sometimes it won't go into 2nd, yes that is completely normal. just release the clutch slightly while pulling it into 2nd and it will go right in. takes just a little practice to not let the clutch out too far.
tom
Woodsplinter
Phoenix/AZ
Tom, thanks. I've been letting the clutch all the way out, pushing it back in and waiting for the gears to slow down before shifting into 2nd. I'll try your technique.
Steel, I was wondering about that too- even when it does go into 2nd it feels rough and it's a bit of a battle to get it into gear.
Any thoughts on that Tom?
nosajb15af
Akron, Ohio
Anyone know where I can buy a first gear countershaft? this gear looks like someone had the sliding gear 1/2 was engaged and hammered on it. Half the gear is spun off, the truck still drives ok, but first engages hard and obviously I cant put much pulling pressure on this gear.
nosajb15af
Akron, Ohio
Haha, this is what im looking at. Any input would be appreciated on where I can get a new or used shaft/gear. Id prefer not to buy an entire transmission.
nosajb15af
Akron, Ohio
Well, its not a new shaft, but I think the used is ok. Old gears are heated and dropped in place. Anyone see a reason i shouldn't run this?
gringeltaube
Staff Member
2,682
Montevideo/Uruguay
1st counter-gear looks much better now!
So drive- and 5th-counter gear were swapped already? Is that dirt I see, to the left side of 5th?? .... or some severely pitted tooth flanks? :?
G.
nosajb15af
Akron, Ohio
G.
Both, the dirt has been cleaned up but its pitted. Swapping was easy, pressed off the old shaft, then heated the gears and dropped them on the new. All my gears are slightly pitted one side. The transmission looks like it sat unused in a moisture environment for awhile. But teeth are all in good shape, along with the syncros.
