goodguyzy
- 13
- 38
- medford oregon
Im assuming that your bob tailing it? Get ready for a bumpy ride. I could make one but won't be for a bit.
Sorry about the late response. I installed the valve body heater that came with some of the trucks and that fixed it to the point, were it only took about 5 to 10 minutes for it to start working. (about the time to get all the air tanks pumped up)Okay so we had a warm day a bam it works, so what's the fix? We were going to send this truck north and this will be a pain up there.
Matt, I don't get it, did you manhandle the steering wheel w/ the engineIf you turn the front wheels all the way to one side, you can access the U joint grease zerk.
Just remember to do this with the engine running or you'll have to clean up a power steering fluid mess like I did.![]()
gpp111 you can shift two gears at a time up to tenth gear said:Just read the thread again and it been awhile. You can skipp as many gears as you want buy pulling up on the shift handel. I can go from 6th to 10th to 14th to 16th by like I said just as you pull it out of one gear lift up on the shift handel.
I had the front wheels off the ground. Without the power steering pump running, I think it builds pressure where it wouldn't normally and that fluid comes out of the filler cap.Matt, I don't get it, did you manhandle the steering wheel w/ the engine
off and did it cause a burp or something ?
But thanx for the tip!
