M923 13 Speed Swap
Crf450x
350
Fall Branch, TN
gotcha. my dual disk south bend i had in my hopped up cummins had similar pins (looked more like dowel pins) to keep the intermediate plate from riding on the first and sec stage clutch plates while the pedal was depressed. which is what give it its rattling sound.
Yep same thing. The 5 button thing just confused me. I’m gonna have to ask what that’s about. It’s wrote on every piece.
simp5782
Feo, Fuerte y Formal
9,496
Mason, TN
Rear transmission mounts are not always needed. The mount is designed to flex with torque to keep the tailshaft in line. Over support any weight.
You are running just a 250. It won't be torqueing that much back there.
Bolt the angle iron to the frame rail and use the leaf pack transmission mount setup.
Crf450x
350
Fall Branch, TN
So you think that is a better option than the factory mount? Care to say why?
Crf450x
350
Fall Branch, TN
Rubber deteriorates. And causes noises like this
Noted. I will see what I can come up with.
Know any alternatives for the trans temp sensor? I evidently broke mine somewhere along the way. The cheapest oem one I can find is $35. I’d guess any one wire coolant temp sensor would work fine?
simp5782
9,496
Mason, TN
Yes. On a manual transmission I wouldn't worry about one really. It doesn't need a cooler or temp gauge
74M35A2
340
Livonia, MI
Should be 6 buttons. I did mine with all new stuff from Eaton. Important they are exactly perpendicular to the flywheel surface so the clutch releases well and the disc can float and move and release tension off the flywheel side plate. I aligned my buttons with an end wrench and used a combination square along the flywheel lip with the rule sticking straight down into the dish, rotate buttons until each is perfectly parallel with the rule.
Crf450x
350
Fall Branch, TN
Good idea. I’m hoping I can find them locally tomorrow. Supposed to quit raining for a few days and I’d like to get the trans in.
simp5782
9,496
Mason, TN
Just had another thought. How well will the leaf spring mount work with the trans not being centered?
Fine. Just make one perch sit out further than the other on the frame. Mine i bolted 2 pieces of angle iron together. Top was for the cab support. Lower was for the trans spring
It only flexes a little bit if you could even see it really without it being in low range and a severe load on it
simp5782
9,496
Mason, TN
This is a long shot but does anybody know if the Allison yoke will fit the fuller trans?
Probably not. You can get a companion flange for the input on the transfer case and use a 1710 joint type jackshaft. Which is what your trans output yoke is
The mechanics style joint the military uses in that 72 series isn't common in the civilan world
On my transmission swap I moved the transfer case back to make a more common application of parts available
Crf450x
350
Fall Branch, TN
Dang. I’m gonna have to look into that. I’ll probably just take my shaft to the driveshaft shop and tell him to make something work.
Spicer made a bastard joint at one time but it’s discontinued and I can’t find one.
simp5782
9,496
Mason, TN
Spicer makes a morph joint that is a 92 to 1710. But not to a 72 series. It's small and obsolete
92 series are used on the 915 trucks
Crf450x
350
Fall Branch, TN
Ah I thought 5 tons used the 8.5c/85wb. Never measured mine, just found that in a thread on here somewhere. Either way I guess that plan won’t work.
Crf450x
350
Fall Branch, TN
Another note, just for the information, I decided to go ahead and order that starter spacer and see what happened. It was the right shape and the bolt pattern is correct. But it is .470” thick, the bolt holes are too small, and the raised part around the center hole has to be cut off. So I just had my brother modify that one. He cut off the raised part and cut it down to .330”. I don’t have it back yet, but I’ll post pictures when I install it.
Crf450x
350
Fall Branch, TN
Took some pictures today. Plenty clearance everywhere. From the center of the transmission u joint to the face of the transfer case yoke is 9-1/8”.
Also got some new rear cab mount bushings. Just thought the difference was kinda funny.
