MEP-004A, No output
peapvp
1,659
Basehor, KS
Six pack?! Great, I am sure you can handle more than a six pack, I doubt though that your A11 will be able to keep up with you......
I am still wiring A11. This so far it took a 6 pack. Also Houston is flooded big time. Glad I moved out of Houston 40 miles North.
Fuse holder is installed, but if you put it between the J connectors which I did, you will have a hard time torqueing the holder so it will be tight.
When I finish I will show pics.
KLChurch
Montgomery/TX
I have one set of wires left to install on the trans.
It has the fuse holder that was installed on the other trans.
Question: If I put a 20 amp fuse in the holder instead on cutting off the holder could I use it as is?
Correction the largest fuse I have is 15 amp.
That would be H2 terminal #2
Kris
peapvp
1,659
Basehor, KS
No, should not be higher then 3 Amps - anything larger and T2 can burn out
Kris
KLChurch
Montgomery/TX
Ok that will be easier. So I will be taking pics tonight after I eat.
After that in the morn I will post the prelim test before I install A11.
Kris
peapvp
1,659
Basehor, KS
OK, enjoy your Dinner! The fuse / fuseholder you had on the 100VA T2 would be fine to use, but I am not sure of Guy [Guyfang] had suggested to you for panel mounting
Kris
peapvp
1,659
Basehor, KS
peapvp
1,659
Basehor, KS
Ok, you got one fuse for each leg, meaning connecting point on the T2 H side - I would take the old fuse for the 100VA transformer out as it defies the logic of having a panel mounted fuse holder - it really doesn’t make any difference if the fuse winds up in the connection to H1 or H2 for that matter as long there is a fuse - I didn’t realize that you had implemented guys panel fuse holder already as in the new wiring diagram for this transformer, so just take out the old fuse holder and splice the two X9 wires to terminal #2 H1 on T2 that will work fine then
No
Now I have one set of wires fused and the other set fused.
The first set was from one diagram and the other from the new diagram.
Kris
KLChurch
Montgomery/TX
Ok, let's see Kris
1. Please measure the resistance on Rheostat R2 which is your Voltage Adujst on your Front Panel in your cubicle
This Rheostat has three terminal lugs - two of them are jumpered - please set Voltage adjust to lowest, left setting of dial and measure the resistance with the red test lead on the single connection / terminal and black lead on the jumpered connection / terminals
When done with testing please set dial in middle position
2. Please post some pictures of newly installed T2 in your A11 from some different angles
You may want to have a couple spare fuses, we may have to put 3Amp in like in the situation Brian had
After that we should be ready to go
Thanks Peter
The readings are as follow:
full to left 14.0 ohms
midway 119.0 ohms
full increased 244.0
Kris
Had to wait for the monsoon to stop.
peapvp
1,659
Basehor, KS
Ok,
I guess we are ready! Now, if you have, attach two Alligator Clips to your DMM's test lead - if you don't know of what that is or how they attach than you may not have them or never used them before - On some DMM's they come with the included test leads - not sure what you get with a Klein DMM.....
If you do have them please attach them as indicated and set your DMM to DC - put your A11 into your Genset first without the cover and connect both P/J connectors - then hook up the test leads as indicated in the pic below, as a reminder, both leads have to be connected at the same time as this is 2 pictures combined into one picture - you may have to zoom into the pic to see / read the detail
This way we can monitor T2 during field flash and then excitation while your starting the Genset - this way you wont have to to hold the test leads by hand onto the Test Points.
Hopefully your test leads are long enough so you can put your DMM on top of the Genset above the front panel and monitor everything - maybe you could do a video of it - the entire sequence start with field flash and then going into run with switch to excitation. The switch between field flash to excitation happens automatically when you release the Stop/Run/Start Switch from Start to Run and everything is working.
That would be great! This way we know for sure of what we got!
midway 119.0 ohms
Kris
peapvp
1,659
Basehor, KS
Kris, you can text me the Video, I will upload the video to my YouTube Channel and then post it here as embedded video.
Your Monsoon arrived here yesterday late afternoon in Basehor / Kansas City, Kansas with plenty of windgust's but very little rain moving NNW at a good pace - I guess you fellows in TX got most of the rain
I'm setting up for the start up test but don't know how to insert a video.
Kris
KLChurch
Montgomery/TX
Here in texas we keep all the rain (40 inches in 48 hours). Kinda stingy. But I don't think you want to have 4 feet of water in your house. Even though the rain is gone up to you, the streets are still flooded and some of the schools are still closed. Why people move into flood potential areas are beyond me.
I guess they are immortal.
Ok, will video the trial.
What DC voltage should I expect?
peapvp
1,659
Basehor, KS
Great, around 48VDC, like in test #2 for the A11, +/- 5VDC
and when everything is running OK, show your Voltage Gauge on your front panel and use the Voltage adjust Rheostat to see minimum Voltage to maximum Voltage on the Gauge, then move the dial back to 120VAC or 208VAC and see if the Dial of the Rheostat is fairly in the center.
What you see on the gauge depends on where your selector switch is set to: L1-L3, L2-L3, L1-L2, L1-Lo, L2-Lo, L3-Lo
any position between phase and Lo is 120VAC between any two phases 208VAC - this way you can check if your getting voltages on every coil system
dial = knob
KLChurch
Montgomery/TX
Good,
I have two settings mV and V
So I will set it at V
Now I just have to find enough guts to do it.
Ill have a friend video it.
But I did not recheck the config board.
Kris
peapvp
1,659
Basehor, KS
dial = knob
Good,
Kris
KLChurch
Montgomery/TX
dial = knob
So you want me go thru all the settings in the video?
Kris
