stb64
- 17
- 18
- hohenfels germany
Dot 5 for all parts that come in contact with brake fluid. Mineral oil based lubricants would ruin the seals.
For the air side, the prescribed lubricant is OHT, a mineral oil based hydraulic fluid. Soak the felt seal before assembly. Also, a few squirts are to be added periodically through the hole on the rear, there is a little plug.
Some air packs do not have that plug, the air pipe must be removed to add the lubricant.
When i can´t get OHT, i use air tool oil, or 10wt in a pinch. I also like to put a very light coat of grease on the inside of the air cylinder, as the felt seal will not wipe the oil over the entire surface, and i put silicone grease under the dust boots on the master cyl and wheel cylinders to stop rust.
