My cucv lift
TCUCV
Chocowinity, NC
So Cucvnut . . . what did you end up doing to the front drive shaft? I'm looking at running some of those zero rates front and rear but I know my front shaft is at its limit with just the 4" lift...how's your rear drive shaft holding up with no mods? Thanks for the info
Cucvnut
68
Carver, Oregon
The rear shaft is fine no issues. The front I had to make a new one I took the old one cut it in half and cut another one I had and made it longer and welded it together.
TCUCV
Chocowinity, NC
Thats pretty cool, I bet a lot cheaper than buy a newer shaft . . . I'm gonna have to figure something out on mine when I actually get those zero rates
Dave87
Holland,Michigan
Cucvnut what pitman arm did you use. I'm setting up a cross over/ Y link steer kit. I have a 2wd steer box. I'm not sure what Pittman arm I need. Any advice?
moose1008
King, North Carolina
Nice looking truck Cucvnut! I'm in the process of lifting my truck and was wanting to use the zero rate blocks and wfo plates. My only concern is not being able to hook the sway bar back up with this set up. How does ur truck handle on the road?
Cucvnut
68
Carver, Oregon
WIth out the say bar its not that bad it leans a little in the turns but besides that nothing to complain about. if you want to keep the sway bar ord sells the sway bar kit.
moose1008
i feel like a D.A. as soon as i posted i went back through and found a post about this a page or tow back.... can we say hi im the new guy... thinks for repling tho.. I think I'll try it with no swaybar and if it sways more then my liking then i will get the ord kit... thanks again!
Cucvnut
68
Carver, Oregon
If you want the kit I have one I don't need for less than ORD sells it.
no worrys about feeling like a da im glad to help in anyway.
aggopian
King, NC (As of April 1st)
Great thread and very informative! I had to flip between Google and back several times with terms like "shackle flip" etc, etc. I learned a lot (especially that I have a lot to learn)
Thanx for taking the time to post this.[thumbzup]
Cucvnut
68
Carver, Oregon
At the moment no its just sitting waiting for the new IP (the new one went bad). Once i get the IP ill do an up date on rims and tires and the IP install.
