My New 1028/1031
1,821
Haha, I'm involved in a 3 way love/hate relationship with my M1008. Everytime Devilam96 takes it, it breaks and he has to work on it. Hate! It never fails or falters for me. Love!
Speddmon
Blind squirrel rehabiltator
29
Cambridge, Ohio
I didn't get this vibe, reading your last Pm about the turn signal lights...
AH, yes. But I spoke with "The Great One" last night and he gave me some places to look to solve the mystery. Thanks Warthog ;)
Speddmon
29
Cambridge, Ohio
Well, the turn signal mystery is finally solved, see this post for the full write-up...Turn Signal Issues, Post #13
I was doing some battery wiring for the welder generator in the back when I noticed that the drivers side rear hub was damp after my trip to Kips this week. A quick smell confirmed my suspicion...gear oil, a leaking wheel seal. Luckily I got the hub nut socket I ordered for the rear axle that day and pulled the offending hub and cleaned the bearings, hub and spindle and reassembled with a new seal on Thursday.
Today I finished up installing a battery cutoff switch and running new cables from the front battery of the truck to the welder/generator. I tried to get it going, but I can't get it to start. I know I probably need to bleed my fuel line that I just made to go from the jerry can to the engine, I hope that's all I have to do. I was able to get it to idle a bit with the choke on using starting fluid to get it going and keep it going for a minute.
Maybe at the rally some of you fine folks will help me get it going??????? I don't know anything really about those old Wisconsin engines.
Stretch44875
Super Jr. Moderator
31
Tiro, Ohio
Wisconsin engines are really nothing more than a big briggs and stratton. Just add a coil and distributor. I've got one in the lift, would like to swap it out to diesel. Uses too much propane, and tends to not start when I'm 40 feet in the air. But it does run good.
Speddmon
29
Cambridge, Ohio
That's not a bad idea Stretch. I was contemplating the idea of swapping it out down the road with a diesel, but a propane conversion might be a good idea too...if you get yours changed out, I might want the propane stuff from it. Talk to me before you get rid of it.
Stretch44875
Super Jr. Moderator
31
Tiro, Ohio
will do. It when it wants to start, as in turns over, it starts easy on the propane.
1,821
I think there is enough room in the torch box for a 100# propane tank. FWIW I use propane exclusively for cutting/ heating duties here at the AO
Speddmon
29
Cambridge, Ohio
If I didn't have a very large matching set of Oxy and acetylene tanks, I probably would too. It's hard to part with the acetylene tank cause the big ones are hard to come by...as luck would have it, I wound up with 4 complete sets.
