res0wc18
- 2
- 18
- Everett, Wa
so i know this may sound crazy, but here it is. Would any of these motors even fit?
What about the cummins nhc250?
Turbo it.Jakob said:The only thing I don't like about my stock, non-turbo multi is the acceleration. It leaves alot to be desired there, but other than that, I don't mind the 50-55mph speed limit. I imagine with a turbo and the fuel turned up some, it'd cure most of my acceleration woes.
ditto. turbo it and adjust the fuel and you will be very happy. kits can be found on ebay or sourced piece by piece on here.WillWagner said:Turbo it.Jakob said:The only thing I don't like about my stock, non-turbo multi is the acceleration. It leaves alot to be desired there, but other than that, I don't mind the 50-55mph speed limit. I imagine with a turbo and the fuel turned up some, it'd cure most of my acceleration woes.
thats the canadian MLVW with HIAB cargo/wrecker craneWPNS421, what is that in your avitar
im just looking for the motor and tranny and hopefully the stuff needed to make it work, because i have a nice bobbed duece that needs more power. You have any of those around that you can source?check that link I sent you . they have them state side along with our M113's. We cant buy them so you may as well.
